New Firmware for the Phantom 3 Series
1234567
28497 254 2015-12-22
Guerinomaione
nicwilson Posted at 2016-1-9 00:05
Downgraded some of the phantoms in the group to the last firmware and we are still unable to find a ...
Hi, did you send it in for vibration issue? In this case, they changed motor for solving the problem?
2016-1-11
julienhebben
Hello everybody!
I have a problem... I have tried to install the v1.06 and it failed...
I have got the following log:
[00013258]========== remo-con disconnect. boot(15) ============
[00013306]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0xa1623026].
[00013355]Packet upgrade start...
[00013412]Packet checking...
[00013463]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013511]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013559]Done.
[00013606]Version checking[1]...
[00013673][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013753][03 06][00] v0.0.0.0 -> v2.4.10.7 need upgrade.
[00013806][04 00][00] v1.41.0.0 -> v1.41.0.0
[00026469][11 00][00] device not detected.
[00039017][12 00][00] device not detected.
[00051565][12 01][00] device not detected.
Now the Phantom 3 Advanced is "bipping" very loud and there are no lights...
An idea to help me please? How do you downgrade?
Thanks a lot for your support.
PS: sorry I'm a beginner
2016-1-12
nicwilson
Guerinomaione Posted at 2016-1-12 05:56
Hi, did you send it in for vibration issue? In this case, they changed motor for solving the probl ...
No,  I am saying we have never had nor seen any vibration issue in any of the P3P's in the group,  so we are saying to those saying its a generic firmware issue they are wrong,  there is something else causing it not the firmware or not just the firmware as none of us have the issue on any firmware version.
2016-1-16
jonas.stenberg
Flight distance : 103937 ft
Sweden
The latest firmware update introduced A LOT of vibrations in my P3A. Day before it was smooth as butter. I tried to lower the gains and it helped.
But still can DJI PLEASE tell us why this is happening suddenly? There are still people out there upgrading and have no clue what to do when the vibrations occur.
Luckily I found this post.
Thanks!
2016-1-25
remy
Flight distance : 363930 ft
Belgium
shane@shardae.c Posted at 2015-12-23 23:10
Just upgraded firmware to latest and now no GPS or IMU calibration function... apart from reinstalli ...
You did install the new app on your phone or tablet olso?  I had the same problem
2016-1-28
remy
Belgium
BIGDZ Posted at 2015-12-22 14:48
The release notes mentions nothing about fixing vibrations in 1.5.3 everyone was experiencing. So no ...
no fix!  just cheked,  if I turn my phantom on (start motors) 2sec everything is okay, then I hear a little more power coming up, then it is starting to shake,
If I lower the gains to 90% then is will take about 6sec when its start to give a little more power.
but still shaking.
Gains to 80% ,problem almost gone,  but after 10sec it will give a bit more power and again shaking.
2016-1-28
remy
Belgium
Rob W Posted at 2015-12-22 15:29
Is the vibration issue fixed in this firmware? Can we fly safely?
no problem not fixed !
2016-1-28
JMBare
How long has it taken you guys to complete the latest on the P3Pv
2016-1-28
DJI-Tim
JMBare Posted at 2016-1-29 06:25
Firmware update usually takes 20-30 minutes
2016-1-28
Guerinomaione
DJI-Tim Posted at 2016-1-29 02:30
Hi, what is dji doing for fixing vibration issue? I had a problem after i upgraded from 1.4 to 1.6.
Give a look please...
https://m.youtube.com/watch?v=QyJGesX_xnk
2016-1-29
Guerinomaione
2016-1-29
jcooper110
Does reducing the gains affect the hovering and landing abilities? Updated by force to 1.6 just to get airborne then reduced the gains and now hovering and landing my p3p acts like it's had too much sake?  Everything works but holding for a still shot and landing in a 2 foot circle is now a major challenge. I have some horrible drone drift with 1.6 and lower gains.
2016-1-30
Naza-PA
Just got new P3A. Updated to the latest FW 1.6.40. Everything at default setttings, no IMU calibration. Calibrated compass before the first flight on P3A request. Nothing to report really, everything works fine. The P3A drone flies like a dream!
2016-1-30
meranomaia
Flight distance : 741 ft
Guerinomaione Posted at 2016-1-30 08:15
Hi, what is dji doing for fixing vibration issue? I had a problem after i upgraded from 1.4 to 1.6 ...
Same problem here. I wrote a mail to the EU support 1 week ago, had no answer yet.
2016-2-1
maurozx27
Argentina
Estimados. Buenas tardes. Me podran ayudar?. Estoy buscando el firmware para el phantom 3 standard ya que cuando estaba actualizando a travez de dji go", la conexion de wifi se desconecto y ahora no arrancan los motores.
2016-4-20
1234567
