john.gual
No luck. I followed the instructions and got 30 seconds of alternating red/green indicator light with D-D-D beeps, then a constant beep with a solid red light. I left it that way for 3 minutes more before shutting down. I still have a red "No Signal" indicator and no live video feed. There are two txt files.
The first file is in the root directory P3X_FW_RESULT_AB.txt :
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:01:04 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.05.0030.bin
Result: Failed.
Upgrading ...
Result: Failed.
========== 2015.12.24 15:02:24 =====================
Result: Failed.
========== 2014.01.01 00:04:36 remo-con disconnect======
Result: Failed.
========== 2015.12.24 19:59:54 =====================
Result: Failed.
========== 2015.12.25 09:10:49 =====================
========== 2015.12.25 09:12:11 =====================
Result: Failed.
========== 2015.12.25 09:33:53 =====================
Result: Failed.
Packet: P3X_FW_V01.04.0010.bin
Result: Failed.
Result: Failed.
========== 2015.12.25 12:58:09 =====================
========== 2015.12.25 12:58:58 =====================
Result: Failed.
Result: Failed.
ALSO: There is a second txt file: MISC>LOG> P3X_FW_AB.txt and here is what it contains:
[00014232][01 00] Firmware upgrade finished successfully.
[00014348]Done.
[00014381]Packet [C:\P3X_FW_V01.06.0040.bin] resumed, card sn [0x2810ef61].
[00014422]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014485]Version checking[2]...
[00014562][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014643][03 06][00] v2.1.6.18 -> v2.4.10.7 need upgrade.
[00014680][04 00][00] v1.38.0.0 -> v1.41.0.0 need upgrade.
[00014784][11 00][00] v1.6.1.0 -> v1.7.15.1 need upgrade.
[00014875][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014947][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015038][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015117][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00027653][15 00][00] device not detected.
[00027738][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00027878][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00027926][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027957][01 00][05] v1.26.4315 -> v1.26.4315
[00027988][01 01][00] v1.6.2736 -> v1.26.4315 need upgrade
[00040517][08 00][00] device not detected.
[00040570][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00040605]Done.
[00040640]Firmware upgrading[2]...
[00040785][01 01] Firmware upgrade start...
[00071051][01 01] Firmware upgrade finished successfully.
[00071106][12 00] Firmware upgrade start...
[00139694][12 00] Firmware upgrade finished successfully.
[00139746][12 01] Firmware upgrade start...
[00210003][12 01] Firmware upgrade finished successfully.
[00210049][12 02] Firmware upgrade start...
[00277653][12 02] Firmware upgrade finished successfully.
[00277704][12 03] Firmware upgrade start...
[00343756][12 03] Firmware upgrade finished successfully.
[00343814][17 00] Firmware upgrade start...
[00478492][17 00] Firmware upgrade finished successfully.
[00478548][17 01] Firmware upgrade start...
[00558522][17 01] Firmware upgrade finished successfully.
[00558562][11 00] Firmware upgrade start...
[00610777][11 00] Firmware upgrade finished successfully.
[00611006][03 06] Firmware upgrade start...
[00943813][03 06] Firmware upgrade finished successfully.
[00943874][09 00] Firmware upgrade start...
[00997452][09 00] Firmware upgrade finished successfully.
[00997511][04 00] Firmware upgrade start...
[01056742][04 00] Firmware upgrade finished successfully.
[01056776]Done.
[01056807]Version checking[3]...
[01056887][03 05][00] v34.2.0.9 -> v34.2.0.9
[01056971][03 06][05] v2.4.10.7 -> v2.4.10.7
[01057010][04 00][05] v1.41.0.0 -> v1.41.0.0
[01057127][11 00][05] v1.7.15.1 -> v1.7.15.1
[01057226][12 00][05] v1.10.0.0 -> v1.10.0.0
[01057326][12 01][05] v1.10.0.0 -> v1.10.0.0
[01057426][12 02][05] v1.10.0.0 -> v1.10.0.0
[01057527][12 03][05] v1.10.0.0 -> v1.10.0.0
[01070066][15 00][00] device not detected.
[01070156][17 00][05] v1.1.1.7 -> v1.1.1.7
[01070282][17 01][05] v1.0.2.7 -> v1.0.2.7
[01070326][19 00][00] v1.0.8.96 -> v1.0.8.96
[01070359][01 00][05] v1.26.4315 -> v1.26.4315
[01070392][01 01][05] v1.26.4315 -> v1.26.4315
[01082936][08 00][00] device not detected.
[01082988][09 00][05] v2.13.0.0 -> v2.13.0.0
[01083021]Packet upgrade failed at version checking.
[00064431]========== remo-con disconnect. boot(15) ============
[00064465]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00064515]Packet upgrade start...
[00064554]Packet checking...
[00064589]Packet vlink 01.06.0040 <-> 01.05.0030.
[00064658]Done.
[00064689]Version checking[1]...
[00064758][03 05][00] v34.2.0.9 -> v34.2.0.9
[00064838][03 06][00] v2.4.10.7 -> v2.4.10.7
[00064876][04 00][00] v1.41.0.0 -> v1.41.0.0
[00064998][11 00][00] v1.7.15.1 -> v1.7.15.1
[00065098][12 00][00] v1.10.0.0 -> v1.10.0.0
[00065203][12 01][00] v1.10.0.0 -> v1.10.0.0
[00065298][12 02][00] v1.10.0.0 -> v1.10.0.0
[00065398][12 03][00] v1.10.0.0 -> v1.10.0.0
[00077933][15 00][00] device not detected.
[00078033][17 00][00] v1.1.1.7 -> v1.1.1.7
[00078148][17 01][00] v1.0.2.7 -> v1.0.2.7
[00078198][19 00][00] v1.0.8.96 -> v1.0.8.96
[00078320][01 00][00] v1.26.4315 -> v1.26.4315
[00078364][01 01][00] v1.26.4315 -> v1.26.4315
[00090897][08 00][00] device not detected.
[00090959][09 00][00] v2.13.0.0 -> v2.13.0.0
[00090994]Packet upgrade failed at version checking.
[00014447]========== remo-con disconnect. boot(15) ============
[00014480]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00014512]Packet upgrade start...
[00014550]Packet checking...
[00014590]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014660]Done.
[00014692]Version checking[1]...
[00014752][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014812][03 06][00] v2.4.10.7 -> v2.4.10.7
[00014858][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014952][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015021][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015100][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015176][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015242][12 03][00] v1.10.0.0 -> v1.10.0.0
[00027776][15 00][00] device not detected.
[00027858][17 00][00] v1.1.1.7 -> v1.1.1.7
[00027982][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028042][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028074][01 00][00] v1.26.4315 -> v1.26.4315
[00028113][01 01][00] v1.26.4315 -> v1.26.4315
[00040648][08 00][00] device not detected.
[00040703][09 00][00] v2.13.0.0 -> v2.13.0.0
[00040738]Packet upgrade failed at version checking.
[00014838]========== remo-con disconnect. boot(15) ============
[00014872]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00014907]Packet upgrade start...
[00014956]Packet checking...
[00014992]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015058]Done.
[00015097]Version checking[1]...
[00015170][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015225][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015272][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015387][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015479][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015554][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015635][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015726][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028341][15 00][00] device not detected.
[00028438][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028555][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028615][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028651][01 00][00] v1.26.4315 -> v1.26.4315
[00028686][01 01][00] v1.26.4315 -> v1.26.4315
[00041222][08 00][00] device not detected.
[00041276][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041318]Packet upgrade failed at version checking.
[00015098]========== remo-con disconnect. boot(15) ============
[00015136]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00015171]Packet upgrade start...
[00015208]Packet checking...
[00015251]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015314]Done.
[00015349]Version checking[1]...
[00015435][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015511][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015553][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015692][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015775][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015869][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015969][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016074][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028609][15 00][00] device not detected.
[00028697][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028816][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028867][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028903][01 00][00] v1.26.4315 -> v1.26.4315
[00028944][01 01][00] v1.26.4315 -> v1.26.4315
[00041478][08 00][00] device not detected.
[00041548][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041587]Packet upgrade failed at version checking.
[00014871]========== remo-con disconnect. boot(15) ============
[00014915]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x2810ef61].
[00014954]Packet upgrade start...
[00014991]Packet checking...
[00015029]Packet vlink 01.05.0030 <-> 01.04.0010.
[00015102]Done.
[00015135]Version checking[1]...
[00015206][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015287][03 06][00] v2.4.10.7 -> v2.4.0.5
[00015326][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015526][11 00][00] v1.7.0.0 -> v1.7.0.0
[00015600][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015676][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015759][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015847][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028383][15 00][00] device not detected.
[00028458][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028591][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028657][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028693][01 00][00] v1.26.4315 -> v1.26.4315
[00028730][01 01][00] v1.26.4315 -> v1.26.4315
[00041284][08 00][00] device not detected.
[00041357][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041393]Packet upgrade failed at version checking.
[00014784]========== remo-con disconnect. boot(15) ============
[00014822]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00014856]Packet upgrade start...
[00014896]Packet checking...
[00014938]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015007]Done.
[00015045]Version checking[1]...
[00015109][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015189][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015247][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015369][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00015442][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015517][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015597][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015688][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028226][15 00][00] device not detected.
[00028314][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028439][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028494][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028534][01 00][00] v1.26.4315 -> v1.26.4315
[00028570][01 01][00] v1.26.4315 -> v1.26.4315
[00041117][08 00][00] device not detected.
[00041175][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041209]Done.
[00043249]Waiting for user confirm...
[00053289]Timeout, start upgrade automatically.
[00053371]Firmware upgrading[1]...
[00053416][11 00] Firmware upgrade start...
[00099229][11 00] Firmware upgrade finished successfully.
[00099268]Done.
[00099305]Version checking[2]...
[00099474][03 05][00] v34.2.0.9 -> v34.2.0.9
[00099554][03 06][00] v2.4.10.7 -> v2.4.10.7
[00099597][04 00][00] v1.41.0.0 -> v1.41.0.0
[00099714][11 00][05] v1.7.15.1 -> v1.7.15.1
[00099805][12 00][00] v1.10.0.0 -> v1.10.0.0
[00099902][12 01][00] v1.10.0.0 -> v1.10.0.0
[00099982][12 02][00] v1.10.0.0 -> v1.10.0.0
[00100078][12 03][00] v1.10.0.0 -> v1.10.0.0
[00112615][15 00][00] device not detected.
[00112702][17 00][00] v1.1.1.7 -> v1.1.1.7
[00112823][17 01][00] v1.0.2.7 -> v1.0.2.7
[00112878][19 00][00] v1.0.8.96 -> v1.0.8.96
[00112922][01 00][00] v1.26.4315 -> v1.26.4315
[00112959][01 01][00] v1.26.4315 -> v1.26.4315
[00125497][08 00][00] device not detected.
[00125560][09 00][00] v2.13.0.0 -> v2.13.0.0
[00125594]Packet upgrade failed at version checking.
[00015138]========== 2015.12.24 15:02:25. boot(15) ============
[00015176]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00015211]Packet upgrade start...
[00015255]Packet checking...
[00015298]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015364]Done.
[00015404]Version checking[1]...
[00015485][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015569][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015612][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015722][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015815][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015890][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015986][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016086][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028625][15 00][00] device not detected.
[00028710][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028827][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028883][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028925][01 00][00] v1.26.4315 -> v1.26.4315
[00028961][01 01][00] v1.26.4315 -> v1.26.4315
[00041498][08 00][00] device not detected.
[00041558][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041601]Packet upgrade failed at version checking.
[00276480]========== remo-con disconnect. boot(15) ============
[00276515]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2850f06a].
[00276653]Packet upgrade start...
[00276701]Packet checking...
[00276738]Packet vlink 01.06.0040 <-> 01.05.0030.
[00276807]Done.
[00276848]Version checking[1]...
[00276922][03 05][00] v34.2.0.9 -> v34.2.0.9
[00277002][03 06][00] v2.4.10.7 -> v2.4.10.7
[00277058][04 00][00] v1.41.0.0 -> v1.41.0.0
[00277183][11 00][00] v1.7.15.1 -> v1.7.15.1
[00277296][12 00][00] v1.10.0.0 -> v1.10.0.0
[00277370][12 01][00] v1.10.0.0 -> v1.10.0.0
[00277450][12 02][00] v1.10.0.0 -> v1.10.0.0
[00277541][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014904]========== remo-con disconnect. boot(15) ============
[00014947]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2850f06a].
[00014984]Packet upgrade start...
[00015029]Packet checking...
[00015068]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015137]Done.
[00015175]Version checking[1]...
[00015236][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015315][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015362][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015475][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015555][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015646][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015735][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015810][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028350][15 00][00] device not detected.
[00028426][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028546][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028605][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028646][01 00][00] v1.26.4315 -> v1.26.4315
[00028687][01 01][00] v1.26.4315 -> v1.26.4315
[00041226][08 00][00] device not detected.
[00041286][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041324]Packet upgrade failed at version checking.
[00015056]========== 2015.12.24 19:59:55. boot(15) ============
[00015099]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2850f06a].
[00015136]Packet upgrade start...
[00015178]Packet checking...
[00015217]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015297]Done.
[00015335]Version checking[1]...
[00015495][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015581][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015641][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015759][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015865][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015967][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016042][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016146][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028685][15 00][00] device not detected.
[00028783][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028939][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028997][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029037][01 00][00] v1.26.4315 -> v1.26.4315
[00029077][01 01][00] v1.26.4315 -> v1.26.4315
[00041621][08 00][00] device not detected.
[00041691][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041730]Packet upgrade failed at version checking.
[00252574]========== 2015.12.25 09:10:49. boot(15) ============
[00252608]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x00000000].
[00252642]Packet upgrade start...
[00252676]Packet upgrade failed at state checking (esc = 0).
[00015189]========== 2015.12.25 09:12:12. boot(0) ============
[00015233]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2850f06a].
[00015277]Packet upgrade start...
[00015319]Packet checking...
[00015358]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015430]Done.
[00015469]Version checking[1]...
[00015552][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015633][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015678][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015813][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015921][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016023][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016123][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016223][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028776][15 00][00] device not detected.
[00028859][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028977][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029031][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029072][01 00][00] v1.26.4315 -> v1.26.4315
[00029116][01 01][00] v1.26.4315 -> v1.26.4315
[00041751][08 00][00] device not detected.
[00041818][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041859]Packet upgrade failed at version checking.
[00044836]========== 2015.12.25 09:33:53. boot(15) ============
[00044876]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2810ef61].
[00044917]Packet upgrade start...
[00044970]Packet checking...
[00045012]Packet vlink 01.06.0040 <-> 01.05.0030.
[00045084]Done.
[00045133]Version checking[1]...
[00045217][03 05][00] v34.2.0.9 -> v34.2.0.9
[00045298][03 06][00] v2.4.10.7 -> v2.4.10.7
[00045348][04 00][00] v1.41.0.0 -> v1.41.0.0
[00045459][11 00][00] v1.7.15.1 -> v1.7.15.1
[00045545][12 00][00] v1.10.0.0 -> v1.10.0.0
[00045638][12 01][00] v1.10.0.0 -> v1.10.0.0
[00045735][12 02][00] v1.10.0.0 -> v1.10.0.0
[00045838][12 03][00] v1.10.0.0 -> v1.10.0.0
[00058378][15 00][00] device not detected.
[00058462][17 00][00] v1.1.1.7 -> v1.1.1.7
[00058587][17 01][00] v1.0.2.7 -> v1.0.2.7
[00058657][19 00][00] v1.0.8.96 -> v1.0.8.96
[00058701][01 00][00] v1.26.4315 -> v1.26.4315
[00058743][01 01][00] v1.26.4315 -> v1.26.4315
[00071283][08 00][00] device not detected.
[00071358][09 00][00] v2.13.0.0 -> v2.13.0.0
[00071396]Packet upgrade failed at version checking.
[00014831]========== remo-con disconnect. boot(15) ============
[00014872]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x2810ef61].
[00014912]Packet upgrade start...
[00014963]Packet checking...
[00015004]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015081]Done.
[00015126]Version checking[1]...
[00015211][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015311][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015364][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015430][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015550][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015652][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015750][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015850][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015950][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028493][15 00][00] device not detected.
[00028700][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028834][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028890][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028932][01 00][00] v1.26.4315 -> v1.23.3419
[00028978][01 01][00] v1.26.4315 -> v1.23.3419
[00041521][08 00][00] device not detected.
[00041563]Packet upgrade failed at version checking.
[00015173]========== remo-con disconnect. boot(15) ============
[00015218]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x2810ef61].
[00015267]Packet upgrade start...
[00015309]Packet checking...
[00015355]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015427]Done.
[00015468]Version checking[1]...
[00015540][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015605][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015659][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015714][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015840][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015941][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016017][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016115][12 02][00] v1.10.0.0 -> v1.10.0.0
[00028773][15 00][00] device not detected.
[00028870][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028990][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029056][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029098][01 00][00] v1.26.4315 -> v1.23.3419
[00029143][01 01][00] v1.26.4315 -> v1.23.3419
[00041685][08 00][00] device not detected.
[00041728]Packet upgrade failed at version checking.
[00015090]========== 2015.12.25 12:58:10. boot(15) ============
[00015138]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x2810ef61].
[00015181]Packet upgrade start...
[00015228]Packet checking...
[00015278]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015350]Done.
[00015389]Version checking[1]...
[00015469][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015570][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015624][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015680][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015785][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015960][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016034][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016134][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016225][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028775][15 00][00] device not detected.
[00028876][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029016][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029081][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029129][01 00][00] v1.26.4315 -> v1.23.3419
[00029170][01 01][00] v1.26.4315 -> v1.23.3419
[00015190]========== 2015.12.25 12:58:59. boot(0) ============
[00015239]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x2810ef61].
[00015283]Packet upgrade start...
[00015332]Packet checking...
[00015375]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015453]Done.
[00015495]Version checking[1]...
[00015568][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015648][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015697][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015753][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015868][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015954][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016055][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016148][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016250][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028798][15 00][00] device not detected.
[00028896][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029042][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029113][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029157][01 00][00] v1.26.4315 -> v1.23.3419
[00029200][01 01][00] v1.26.4315 -> v1.23.3419
[00041749][08 00][00] device not detected.
[00041795]Packet upgrade failed at version checking.
[00015241]========== remo-con disconnect. boot(15) ============
[00015281]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x2850f06a].
[00015330]Packet upgrade start...
[00015376]Packet checking...
[00015419]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015497]Done.
[00015541]Version checking[1]...
[00015611][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015711][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015768][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015975][11 00][00] v1.7.15.1 -> v1.7.15.1
[00016059][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016139][12 01][00] v1.10.0.0 -> v1.10.0.0
[00016230][12 02][00] v1.10.0.0 -> v1.10.0.0
[00016330][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028875][15 00][00] device not detected.
[00028966][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029100][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029185][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029227][01 00][00] v1.26.4315 -> v1.26.4315
[00029271][01 01][00] v1.26.4315 -> v1.26.4315
[00041827][08 00][00] device not detected.
[00041885][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041933]Packet upgrade failed at version checking.
