terrylewis
Flight distance : 3517287 ft
Sifu128,
The firmware contains numerous module updates and first checks module versions to determine exactly what needs updating. It then makes one or more passes updating the necessary components. During your initial upgrade session, your battery was upgraded (if needed)
The GO App will actually inform you if the secondary batteries need updating....
To update additional batteries, just put the firmware back on the SD Card. The upgrade process will check versions, and will only update the necessary components (battery)....
While the battery is being upgraded, the center two LEDs on the battery will illuminate..... |
