chrisivan69
DJI-Ken Posted at 2016-1-2 19:13
Did the installation of those antenna boosters require taking anything apart on the controller?
No they are just a reflector , they just slide on the antenna , windsurfer is the brand name . I'll try a different cable , it has full RC and HD inside the house even when I leave the room with controller . I go outside set it all up and everything still 100% then I take off get about 100ft in the air and RC signal just starts going crazy and drops completely . Enters RTH , I land it walk up to it and have full bars up to about 3 ft away . Then I re start everything and get 100% again take off and the RC signal gets weak much faster . Is it because it's 32' F out side and the drone or controller gets too cold ? It's the RC signal mainly but also the HD signal has problems shortly after the RC signal goes out . Also this is very strange (this has only happened to my iPhone 6 while connected to app/controller). The app and phone shut off and phone says it's drained to 0% and has a charge of 100% when I start to fly . And won't turn back on until I plug into wall charger . Then once it's plugged in it turns on and has normal battery 90% with only being on charger for 30 seconds . I read on a forum that someone else has had same phone crash / power drain error and signal loss . So I'm not the only one . I'll keep trying things but it seems to be when the drone/ controller gets cold it has the issues . Inside where it's warm it's fine ? Well I can't fly inside not enough room so I can't really test this except for walking around my house with controller to see if signal drops . Anyways any other ideas ? I'll try more things and see what happens I guess. Thanks for help ! |
