Point of Interest can not enable Intelligent Navigation Mode Unknown Error 202
1048 4 2015-12-29
lvjohn65
I was trying my Phantom 3 Standard here at a local park, and wanted to test the Wayward Points.  I switched the remote with the right hand switch, to the lower position, and the correct screen came up.  I recorded 5 points, and after I pressed apply, the error popped up.  I then tried follow me mode, and the same error popped up.  I'm using an iPhone 6, and I had LTE turned on along with connected to the Phantom 3 WiFi.
Any suggestions on what this could be or how to get Follow Me or the Wayward points working?
Flight Record Screen Shot
2015-12-29
DJI-Patrick
Please confirm if you were using the Intelligent  Navigation under Beginner Mode .
2016-1-4
lvjohn65
DJI-Patrick Posted at 2016-1-4 22:19
Thanks, I got ti figured out.  I had beginner mode off, but I didn't have the other mode (forgot the name) turned on.  It worked like a charm.
2016-1-8
jay6c1
lvjohn65 Posted at 2016-1-8 11:38
Thanks, I got ti figured out.  I had beginner mode off, but I didn't have the other mode (forgot t ...
I am having still problem.
My beginner mode is still ON. Should I turn that OFF?
What else i need to change?
i calibrated again but still not working. Please help.
2016-1-9
DJI-Patrick
jay6c1 Posted at 2016-1-10 07:21
What else i need  ...
Please turn the beginner mode off .
2016-1-10
