TB48 Malfunction
979 3 2016-1-2
rkdauph
Flight distance : 160958 ft
This battery came new and only showed 3 lights when 'fully' charged. DJI Pilot app showed it at 100%. After 3rd test flight in an attempt to reset it. This happened when I pressed it to test it out of the airframe, I wasn't trying to turn it on.
I am returning it. The seller will make it right, just sharing the malfunction because I haven't seen it reported.
Now, well, see video.
2016-1-2
rkdauph
PaulKerry Posted at 2016-1-2 15:20
So far, I've only watched to about 30 seconds in but neither of those procedures you show will shut  ...
I will get it replaced. the battery light stayed lit for almost an hour total. It had been lit up for about 20 minutes when I made the video.
I really don't care if it's the battery or the board. I need usable/reliable equipment.
Ray
2016-1-2
DJI-Tim
rkdauph@gmail.c Posted at 2016-1-3 05:49
I will get it replaced. the battery light stayed lit for almost an hour total. It had been lit up  ...
For the replacement please contact you local dealer or DJI support center. Thank you!
http://www.dji.com/support
2016-1-3
Arrow1969
Flight distance : 400577 ft
PaulKerry Posted at 2016-1-2 21:23
If you watch this, hopefully, you will see the fourth light flash very briefly during power up and p ...
Would be a lot better if you put a commentary on all your videos
2016-1-4
