Phantom 3 Pro "Not Connected" problem
1668 21 2016-1-3
chrisandlucy
Flight distance : 4941 ft
I purchased my Phantom 3 Pro in June 2015 and have flown it successfully many times.  I have not flown it, however, since October 2015 when all was apparently OK, shot some video in my locality and performed a static check in early November 2015 again suggesting all was OK.  Although several updates for the aircraft have been released since then I did not update either the aircraft or controller.  The aircraft FW is version 1.3.2 and the controller version from that update.  I considered it may be prudent to perform these updates even though I have no plans to fly my aircraft during the winter months and to be safe to do so in steps i.e. perform each new upgrade and check all OK before installing the next.  My first step was to check all was OK with the FW versions installed but when I switched on my DJI Go app on my iPad Mini 2 showed the "Not Connected" display and there was no video output or telemetry data being received/displayed on the iPad mini2.
I understand from reading user comments on many forum posts on this that many Phantom 3 Pro (and pprobably for other variants) have experienced this and similar video issues but no clear remedy was ever provided.  Is there a clear solution, is it a hardware problem, a software problem or some combination?  One other factor which may be relevant but so far I have not found any posts which cover it viz. although I have not performed updates on my Phantom 3 Pro (Updates to versions 1.4, 1.5 and 1.6 with corresponding controller and battery updates where relevant are still pending) the DJI Go App in my ipad Mini 2 has been updated  -  this initially happened without my knowledge and I accepted further updates in the belief that all such updates would be 'backward compatible' but perhaps this is not the case!
I would be obliged if anyone can help me resolve my "Not Connected" problem and/or comment on my above ramblings which may shed some light on it  -  before I have to resort to contacting my dealer.  Is it possible that the current DJI Go App (version 2.4.2) has some compatability issues with earlier FW versions, in particular version 1.3.2 which I am using and if so is it possible to re-load an earlier version of the App e.g. 2.4.0 which I believe was the version I last used with a functioning aircraft?  Failing that should I simply try updating my aircraft, controller and battery with the latest version i.e. FW version 1.6 in the hope that the problem will be resolved?  Is it safe and recommended to update to version 1.6 from version 1.3.2?
I look forward to viewing any posts commenting on the above -  with aprehension!
Kind regards in anticipation,
Chris.
2016-1-3
Hawks100
Flight distance : 134580 ft
Do all the updates first and then see if it connects.Not everyone has had problems with the updates.
2016-1-3
DJI-Patrick
Please keep all the firmware versions  up to date .
RC : 1.5.7
Aircraft : 1.6.4
App : 2.4.3
2016-1-3
chrisandlucy
DJI-Patrick Posted at 2016-1-4 08:01
RC : 1.5.7
Aircraft : 1.6.4
Can I safely update directly from FW version 1.3.2 to 1.6.4?
2016-1-4
chrisandlucy
RC : 1.5.7
Aircraft : 1.6.4
2016-1-4
chrisandlucy
RC : 1.5.7
Aircraft : 1.6.4
2016-1-4
chrisandlucy
Can I safely update directly from FW version 1.3.2 to version 1.6.4 without first updating to 1.4 then 1.5?
2016-1-4
chrisandlucy
2016-1-4
DJI-Patrick
chrisandlucy Posted at 2016-1-4 17:35
You can upgrade the firmware directly from version 1.3.2 to version 1.6.4 .
2016-1-4
Chris36
Thank you, DJI-Patrick.  I tried upgrading from aircraft FW version 1.3.2 to 1.6.4 unhappily without success.  I believe I carried out all the steps carefully and correctly (downloaded the correct Phantom 3 Pro 1.6.4 file and copied the .bin version to a 64 GB SD card which was initially empty) but while the upgrade went through the expected steps some 25 minutes later the camera LED remained on permanently RED and shortly afterwards the system emitted a loud "screech" which continued until I powered down the aircraft, signifying a failed operation.  As directed by the upgrade guide v 1.4, I powered on the aircraft again but after a short period (some 20-30 seconds) the camera LED went permanently RED and the "screech" started until I powered down again. I then wondered if after all I should have first upgraded to V1.4.1 so cleared the SD card and copied the 1.4.1 .bin file to it and tried to upgrade but as with the second attempt with the 1.6.4 upgrade, I shortly got the permanent RED LED and "screech."   I tried again with the 1.6.4 but again with the same outcome.  I saved the last .txt and .log files which now appear to display ALL upgrades from the beginning  -  in my aircraft's case, from FW version 1.2.6 and some interesting looking entries in the log file which I do not fully understand but which may tell all or at least much, to a specialist.
I have also encountered problems with the RC.  As I stated in my original description of events, the DJI Go App was updated, currently now at V 2.4.3.  When I set about upgrading the RC and first wished to check the version it was currently running, the Overall Status view in the DJI Go App was blank.  Am I missing something?  It also believe it should state in the Overall Status view or elsewhere when an update is available for the RC, which I have been unable to find!  I am running IOS 9.1 in my iPad mini 2 which I understand should be compatible with the current DJI Go App.
Can you offer any further assistance?  Any help would be much appreciated as I am beginning to find this whole process rather frustrating!
Kind regards,
Chris36
2016-1-5
DJI-Ken
Flight distance : 1515312 ft
Chris36 Posted at 2016-1-5 23:24
Thank you, DJI-Patrick.  I tried upgrading from aircraft FW version 1.3.2 to 1.6.4 unhappily without ...
Chris, a few things to check. Is your Phantom connected to the RC, when you power everything on do you get a green light on the RC. If not do the re-linking process.
If it is connected, then go to the about page again and tell me what it says for aircraft and RC version. RC should say 1.5 and aircraft should say whatever the last update you applied to the BIN file.
If you still show NA on the aircraft, then reformat the SD card in your compute and install 1.3 and try to see if you can get that back. If successful, maybe try to update in sequence instead of jumping.
Let me know how it goes.
Also, here's a good thread on the DJI forum that may answer some questions.http://forum.dji.com/thread-37122-1-1.html
2016-1-5
mattnliz
Hi, I'm having the same problems as you. Did you manage to get yours sorted out? If so how?
2016-1-5
Chris36
Thanks, Ken,
I can confirm the RC does connect to the aircraft (the LH LED on the RC immediately goes from red to green when I power up the aircraft, which goes through its usual 'warm-up' routine with the little jingle and camera gimbal check).  Furthermore, I can shoot video and stills, operate the gimbal, start, stop and rev the motors all of which suggests normal control of the aircraft with the RC.  It did this from the beginning i.e. before I attempted any upgrading and I still achieve the same now after all the failed upgrade attempts.  What I don't get is any 'useful' data on the iPad mini2 connected to the RC.  In the message box space where it normally displays Safe to Fly with and without GPS etc. the box is black with white letters stating Disconnected and there is no telemetry data, no video from the camera, I cannot format the SD card I cannot set any parameters e.g. max height, distance or RTH safe height etc.  Where I believe it should inform me if there is a FW update for the RC there is nothing and the screens which should show the version of the RC FW are just blank (except the 'About' page does show the DJI Go App version which is 2.4.3).
Would it help if I copied the contents of the .txt and .log files whose details will mean a lot more to you than me and may suggest why I can't successfully update the aircraft FW though I don't think this data will provide any information of why the DJI Go App displays "Disconnected."  My feeling about the latter is Disconnect means between the iPad and the RC since the RC seems to be controlling the aircraft OK.  I have now tried 3 different USB leads, all of which work normally with the iPad and other items and I have tried my iPhone 5 in place of the iPad mini 2 but it behaved the same i.e. still displayed "Disconnected."  I don't know what else I can do in that area but maybe you have some suggestions to make.
Meanwhile I will try reformatting the SD card, and try to re-install FW version 1.3.2 and hope the aircraft just beeps and provides a .txt file which says abort because the firmware on the SD card is the same or earlier than that on the aircraft.  After that I will re-try to upgrade with FW version 1.4.1 and if successful 1.5 then 1.6 and see what happens  -  but I am not very confident I will succeed and the question about getting the RC and DJI Go App to "talk" and start showing some telemetry data with video from the camera, seems to be a separate problem to be resolved though I can imagine there can be some related interactions!
2016-1-5
Chris36
mattnliz Posted at 2016-1-5 20:17
Sorry, not yet  -  I'm ever hopeful but not very confident.  I'll post any useful info as soon as I find it!
2016-1-5
joelkinker
I don't see a update for 1.5.7  Only
Phantom 3 Professional Firmware v1.5.0030
Where do I get  the 1.5.7????
2016-1-5
joelkinker
DJI-Patrick Posted at 2016-1-4 15:01
RC : 1.5.7
Aircraft : 1.6.4
Patrick where do we get RC 1.5.7 Don't see it on the download page.  only Phantom 3 Professional Firmware v1.5.0030
2016-1-5
DJI-Patrick
joelkinker@gmai Posted at 2016-1-6 08:13
Patrick where do we get RC 1.5.7 Don't see it on the download page.  only Phantom 3 Professional F ...
Please download the firmware v1.6.4 here : http://dl.djicdn.com/downloads/phantom_3/P3X_FW_V01.06.0040.zip
You can download RC firmware in DJI Go App if you connect your device to RC .
2016-1-5
DJI-Patrick
Chris36 Posted at 2016-1-6 03:40
Thanks, Ken,
I can confirm the RC does connect to the aircraft (the LH LED on the RC immediately go ...
Please confirm you've downloaded the right firmware : http://dl.djicdn.com/downloads/phantom_3/P3X_FW_V01.06.0040.zip
And take a look at the instruction : http://dl.djicdn.com/downloads/p ... e_Guide_en_v1.4.pdf
If the upgrade keeps failing , please post the upload log here .The file name should be: P3_FW_LOG_AB.txt
To find the right file, please try to access the Hidden Folder of the SD card by this way:
For Windows: http://windows.microsoft.com/en- ... den-files=windows-7
For MAC: http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2016-1-5
Chris36
These are the steps I've taken following advice from Patrick and Ken:
1. Re-formatted my 64 GB SD card exFat in my PC (I am unable to do so using the RC and aircraft)
2. Copied the .bin file (P3X_FW_V01.03.0020.bin  93,630 KB) and went through the aircraft upgrade.  I had hoped this would simply 'abort' with a .txt message stating FW same or higher than on SD but the outcome was the same as after the first 'failed' attempt to upgrade directly to FW version 1.6.4 and all subsequent upgrade attempts as described in what follows.  Note that the aircraft appeared to be upgrading on the first attempt from 1.3.2 to 1.6.4 with the camera LED alternately flashing REd and Green for the full 25 minutes or so but ultimately ending in failure.  All subsequent attempts to upgrade resulted in about 12-14 seconds of camera LED flashing alternate RED and GREEN with appropriate beeps then permanent RED and a permanent loud 'screech.'
3. Systematically tried upgrading from the present FW version 1.3.2 first to 1.4.1, then 1.5.3 and finally 1.6.4.  All attempts failed.  The aircraft switches on, performs the gimbal check, emits the little jingle and commences 12-14 seconds of RED-GREEN alternate flashing of camera LED then permanent RED and 'screech' until I power down aircraft.
4. Now I can't be sure whether the FW version 1.3.2 is still "FULLY" functional in my aircraft but the RC can certainly control all functions I was able to check.  The RC immediately connects to the aircraft when it and the aircraft are powered on in the correct order.  The motors start, rev up etc. with the joysticks in what seems the normal way, the camera gimbal tilts on command and I can command video and still pictures as verified when I check the SD card in my PC.
So this leaves me with two problems which I suspect are not directly connected: the first is an aircraft which failed to upgrade and in which it is not clear if the still resident FW version 1.3.2 can be trusted after all the failed upgrade attempts.  The main problem is "how do I resolve this problem?"
The second problem is that the RC controller (which appears to be itself working OK) fails to connect or communicate with my iPad mini 2.  I haven't flown the aircraft since late August 2015 on which occasion all elements were working satisfactorily viz. aircraft on FW version 1.3.2, RC controller (on the version it successfully upgraded to when I upgraded the aircraft from 1.2.6 to 1.3.2), the DJI Go App on version 2.4.0 or 2.4.1 (I'm not sure which!) and the iPad mini 2 with IOS version 8.3.  Since then (about August 20, 2015) the the iPad IOS was updated to 9.1 and the DJI Go App to 2.4.3 and when I first connected the iPad mini 2 to the RC I got the "Disconnected" message in the upper centre of the display and when the aircraft was powered on no video, no telemetry at all and seemingly no other connection.  None of the parameters which can be set e.g. maximum height, distance, SD card format, etc.  Version numbers of aircraft or RC are not displayed and in general all the appearances are that the iPad mini 2 simply does not recognise the existence of the RC let alone the aircraft.  This also means that no option to upgrade the RC is provided.  Since the RC worked OK with previous versions of the DJI Go App and IOS I suspect the present failure is due to some incompatibility in the versions!  Either the DJI Go App version 2.4.3 doesn't work with my old version of the RC or IOS 9.1 doesn't or the combination of both!  The problem is, of course, as far as I know, that I can't go back to these older versions to try!  The questions then are do such incompatibilities really exist and/or in either case what can I now do to resolve the problem?
As far as I can see these two problems are not related as the aircraft should have updated properly without the RC ever being switched on.  The fact that I tried BEFORE attempting any updating and found that the RC was "Disconnected"  meaning, I believe, it did NOT RECOGNISE the iPad mini 2 due to the version conflict(s) should not have had any influence on the success or otherwise of updating the aircraft FW.
I saved all the aircraft .txt and Log messages from my various attempts and will gladly provide these if helpful but to start I include below two Log files, one showing the update from FW version 1.2.6 to 1.3.2 the second is from my last failed attempt to update frm 1.3.2 to 1.6.4.
I hope this information will help you to offer solutions to my two problems.  Thank you in anticipation,  Chris36.
Log.txt for earlier upgrade from 1.2.6 to 1.3.2 :-
[00013124][01 00] Firmware upgrade finished successfully.
[00013232]Done.
[00013261]Packet [C:\P3X_FW_V01.02.0006.bin] resumed, card sn [0xb0ce4281].
[00013292]Version checking[2]...
[00013356][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013421][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013455][04 00][00] v1.36.0.0 -> v1.38.0.0 need upgrade.
[00013505][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013625][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013690][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013785][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013880][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013954][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014088][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014185][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014285][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014349][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014376][01 00][05] v1.15.3056 -> v1.15.3056
[00014406][01 01][00] v1.5.2735 -> v1.15.3056 need upgrade
[00014454][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014481]Done.
[00014511]Firmware upgrading[2]...
[00014665][01 01] Firmware upgrade start...
[00044946][01 01] Firmware upgrade finished successfully.
[00045008][04 00] Firmware upgrade start...
[00102756][04 00] Firmware upgrade finished successfully.
[00102788]Done.
[00102815]Version checking[3]...
[00102863][03 05][00] v34.2.0.9 -> v34.2.0.9
[00102923][03 06][00] v2.2.6.8 -> v2.2.6.8
[00102957][04 00][05] v1.38.0.0 -> v1.38.0.0
[00102998][09 00][00] v1.7.0.3 -> v1.7.0.3
[00103108][11 00][00] v1.6.1.0 -> v1.6.0.0
[00103226][12 00][00] v1.8.0.0 -> v1.8.0.0
[00103298][12 01][00] v1.8.0.0 -> v1.8.0.0
[00103399][12 02][00] v1.8.0.0 -> v1.8.0.0
[00103478][12 03][00] v1.8.0.0 -> v1.8.0.0
[00103609][15 00][00] v1.1.2.0 -> v1.1.2.0
[00103692][17 00][00] v1.1.1.6 -> v1.1.1.6
[00103813][17 01][00] v1.0.2.5 -> v1.0.2.5
[00103857][19 00][00] v1.0.8.96 -> v1.0.8.96
[00103893][01 00][05] v1.15.3056 -> v1.15.3056
[00103923][01 01][05] v1.15.3056 -> v1.15.3056
[00103962][08 00][00] v0.11.0.4 -> v0.11.0.4
[00103991]Packet upgrade finish successfully.
[00012643]========== 2015.08.03 11:13:10. boot(15) ============
[00012679]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x11112615].
[00012714]Packet upgrade start...
[00012757]Packet checking...
[00012798]Done.
[00012834]Version checking[1]...
[00012903][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012983][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013039][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013096][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013226][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013322][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013425][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013521][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013598][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013734][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013812][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013932][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014003][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014039][01 00][00] v1.15.3056 -> v1.15.3056
[00014079][01 01][00] v1.15.3056 -> v1.15.3056
[00014124][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014160]Packet upgrade cancelled at version checking.
[00012663]========== 2015.08.09 13:41:57. boot(15) ============
[00012696]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x11112615].
[00012725]Packet upgrade start...
[00012761]Packet checking...
[00012793]Done.
[00012823]Version checking[1]...
[00012881][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012945][03 06][00] v2.2.6.8 -> v2.2.6.8
[00012983][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013035][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013125][11 00][00] v1.6.0.0 -> v1.6.0.0
[00013196][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013261][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013336][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013401][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013550][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013610][17 00][00] v1.1.1.6 -> v1.1.1.6
[00013731][17 01][00] v1.0.2.5 -> v1.0.2.5
[00013775][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013806][01 00][00] v1.15.3056 -> v1.15.3056
[00013840][01 01][00] v1.15.3056 -> v1.15.3056
[00013883][08 00][00] v0.11.0.4 -> v0.11.0.4
[00013995]Packet upgrade cancelled at version checking.
[00012818]========== 2015.08.09 13:55:50. boot(15) ============
[00012856]Packet [C:\P3X_FW_V01.02.0006.bin] detected, card sn [0x11112615].
[00012892]Packet upgrade start...
[00012938]Packet checking...
[00012976]Done.
[00013013]Version checking[1]...
[00013071][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013151][03 06][00] v2.2.6.8 -> v2.2.6.8
[00013197][04 00][00] v1.38.0.0 -> v1.38.0.0
[00013258][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013371][11 00][00] v1.6.1.0 -> v1.6.0.0
[00013463][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013542][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013631][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013732][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013888][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013997][17 00][00] v1.1.1.6 -> v1.1.1.6
[00014115][17 01][00] v1.0.2.5 -> v1.0.2.5
[00014186][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014222][01 00][00] v1.15.3056 -> v1.15.3056
[00014261][01 01][00] v1.15.3056 -> v1.15.3056
[00014312][08 00][00] v0.11.0.4 -> v0.11.0.4
[00014351]Packet upgrade cancelled at version checking.
[00013418]========== remo-con disconnect. boot(15) ============
[00013530]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00013634]Packet upgrade start...
[00013754]Packet checking...
[00013792]Done.
[00013828]Version checking[1]...
[00013892][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013952][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00013994][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014057][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014172][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014243][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014328][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014426][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014506][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014640][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014717][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00014843][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00014976][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015014][01 00][00] v1.15.3056 -> v1.23.3419 need upgrade
[00015052][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00015104][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00015140]Done.
[00017177]Waiting for user confirm...
[00027214]Timeout, start upgrade automatically.
[00027287]Firmware upgrading[1]...
[00039894][01 00] Firmware upgrade start...
[00014227][01 00] Firmware upgrade finished successfully.
[00014270]Done.
[00014307]Packet [C:\P3X_FW_V01.03.0020.bin] resumed, card sn [0x90ce2654].
[00014349]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014416]Version checking[2]...
[00014497][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014562][03 06][00] v2.2.6.8 -> v2.2.6.19 need upgrade.
[00014603][04 00][00] v1.38.0.0 -> v1.40.0.0 need upgrade.
[00014664][09 00][00] v1.7.0.3 -> v1.7.0.3
[00014777][11 00][00] v1.6.1.0 -> v1.7.0.0 need upgrade.
[00014851][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014932][12 01][00] v1.8.0.0 -> v1.8.0.0
[00015006][12 02][00] v1.8.0.0 -> v1.8.0.0
[00015097][12 03][00] v1.8.0.0 -> v1.8.0.0
[00015226][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015306][17 00][00] v1.1.1.6 -> v1.1.1.7 need upgrade.
[00015426][17 01][00] v1.0.2.5 -> v1.0.2.7 need upgrade.
[00015482][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015515][01 00][05] v1.23.3419 -> v1.23.3419
[00015551][01 01][00] v1.15.3056 -> v1.23.3419 need upgrade
[00015608][08 00][00] v0.11.0.4 -> v0.12.0.4 need upgrade.
[00015646]Done.
[00015682]Firmware upgrading[2]...
[00015824][01 01] Firmware upgrade start...
[00046081][01 01] Firmware upgrade finished successfully.
[00046943][08 00] Firmware upgrade start...
[00565687][08 00] Firmware upgrade finished successfully.
[00565748][17 00] Firmware upgrade start...
[00659539][17 00] Firmware upgrade finished successfully.
[00659590][17 01] Firmware upgrade start...
[00723403][17 01] Firmware upgrade finished successfully.
[00723451][11 00] Firmware upgrade start...
[00771797][11 00] Firmware upgrade finished successfully.
[00772022][03 06] Firmware upgrade start...
[01093066][03 06] Firmware upgrade finished successfully.
[01093139][04 00] Firmware upgrade start...
[01151259][04 00] Firmware upgrade finished successfully.
[01151298]Done.
[01151336]Version checking[3]...
[01151414][03 05][00] v34.2.0.9 -> v34.2.0.9
[01151495][03 06][05] v2.2.6.19 -> v2.2.6.19
[01151539][04 00][05] v1.40.0.0 -> v1.40.0.0
[01151601][09 00][00] v1.7.0.3 -> v1.7.0.3
[01151715][11 00][05] v1.7.0.0 -> v1.7.0.0
[01151815][12 00][00] v1.8.0.0 -> v1.8.0.0
[01151915][12 01][00] v1.8.0.0 -> v1.8.0.0
[01151990][12 02][00] v1.8.0.0 -> v1.8.0.0
[01152089][12 03][00] v1.8.0.0 -> v1.8.0.0
[01152235][15 00][00] v1.1.2.0 -> v1.1.2.0
[01152304][17 00][05] v1.1.1.7 -> v1.1.1.7
[01152424][17 01][05] v1.0.2.7 -> v1.0.2.7
[01152481][19 00][00] v1.0.8.96 -> v1.0.8.96
[01152516][01 00][05] v1.23.3419 -> v1.23.3419
[01152557][01 01][05] v1.23.3419 -> v1.23.3419
[01152608][08 00][05] v0.12.0.4 -> v0.12.0.4
[01152646]Packet upgrade finish successfully.
[00012490]========== remo-con disconnect. boot(15) ============
[00012529]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012566]Packet upgrade start...
[00012606]Packet checking...
[00012645]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012681]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012718]Done.
[00012759]Version checking[1]...
[00012824][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012899][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012949][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013003][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013123][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013208][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013324][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013424][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013509][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013638][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013709][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013834][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013964][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014002][01 00][00] v1.23.3419 -> v1.23.3419
[00014039][01 01][00] v1.23.3419 -> v1.23.3419
[00014094][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014133]Packet upgrade cancelled at version checking.
[00012491]========== remo-con disconnect. boot(15) ============
[00012530]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012567]Packet upgrade start...
[00012611]Packet checking...
[00012650]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012690]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012728]Done.
[00012768]Version checking[1]...
[00012845][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012924][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012965][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013029][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013144][11 00][00] v1.6.0.0 -> v1.7.0.0 need upgrade.
[00013244][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013319][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013425][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013519][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013652][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013740][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013859][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013909][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013950][01 00][00] v1.23.3419 -> v1.23.3419
[00013986][01 01][00] v1.23.3419 -> v1.23.3419
[00014051][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014088]Done.
[00016128]Waiting for user confirm...
[00026165]Timeout, start upgrade automatically.
[00026248]Firmware upgrading[1]...
[00026299][11 00] Firmware upgrade start...
[00078663][11 00] Firmware upgrade finished successfully.
[00078704]Done.
[00078742]Version checking[2]...
[00078807][03 05][00] v34.2.0.9 -> v34.2.0.9
[00078887][03 06][00] v2.2.6.19 -> v2.2.6.19
[00078936][04 00][00] v1.40.0.0 -> v1.40.0.0
[00079012][09 00][00] v1.7.0.3 -> v1.7.0.3
[00079133][11 00][05] v1.7.0.0 -> v1.7.0.0
[00079228][12 00][00] v1.8.0.0 -> v1.8.0.0
[00079323][12 01][00] v1.8.0.0 -> v1.8.0.0
[00079403][12 02][00] v1.8.0.0 -> v1.8.0.0
[00079583][12 03][00] v1.8.0.0 -> v1.8.0.0
[00079742][15 00][00] v1.1.2.0 -> v1.1.2.0
[00079813][17 00][00] v1.1.1.7 -> v1.1.1.7
[00079933][17 01][00] v1.0.2.7 -> v1.0.2.7
[00079993][19 00][00] v1.0.8.96 -> v1.0.8.96
[00080033][01 00][00] v1.23.3419 -> v1.23.3419
[00080072][01 01][00] v1.23.3419 -> v1.23.3419
[00080117][08 00][00] v0.12.0.4 -> v0.12.0.4
[00080153]Packet upgrade finish successfully.
[00012503]========== remo-con disconnect. boot(15) ============
[00012542]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012581]Packet upgrade start...
[00012621]Packet checking...
[00012664]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012702]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012743]Done.
[00012781]Version checking[1]...
[00012843][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012925][03 06][00] v2.2.6.19 -> v2.2.6.19
[00012969][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013027][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013142][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013240][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013338][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013440][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013538][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013682][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013747][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013873][17 01][00] v1.0.2.7 -> v1.0.2.7
[00013927][19 00][00] v1.0.8.96 -> v1.0.8.96
[00013966][01 00][00] v1.23.3419 -> v1.23.3419
[00014004][01 01][00] v1.23.3419 -> v1.23.3419
[00014055][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014095]Packet upgrade cancelled at version checking.
[00012541]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012625]Packet checking...
[00012665]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012705]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012745]Done.
[00012784]Version checking[1]...
[00012879][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013019][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013069][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013124][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013240][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013335][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013436][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013535][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013614][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013752][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013836][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013944][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014004][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014046][01 00][00] v1.23.3419 -> v1.23.3419
[00014086][01 01][00] v1.23.3419 -> v1.23.3419
[00014141][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014182]Packet upgrade cancelled at version checking.
[00012619]========== remo-con disconnect. boot(15) ============
[00012657]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012693]Packet upgrade start...
[00012742]Packet checking...
[00012781]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012821]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012859]Done.
[00012897]Version checking[1]...
[00012977][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013057][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013102][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013162][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013278][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013372][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013453][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013553][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013628][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013779][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013862][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013983][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014042][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014083][01 00][00] v1.23.3419 -> v1.23.3419
[00014124][01 01][00] v1.23.3419 -> v1.23.3419
[00014177][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014213]Packet upgrade cancelled at version checking.
[00012498]========== remo-con disconnect. boot(15) ============
[00012539]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012663]Packet upgrade start...
[00012711]Packet checking...
[00012753]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012792]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012831]Done.
[00012871]Version checking[1]...
[00012952][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013032][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013077][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013151][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013271][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013365][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013464][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013565][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013665][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013812][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013895][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014015][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014072][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014112][01 00][00] v1.23.3419 -> v1.23.3419
[00014152][01 01][00] v1.23.3419 -> v1.23.3419
[00014208][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014263]Packet upgrade cancelled at version checking.
[00012520]========== 2015.08.18 12:34:36. boot(15) ============
[00012561]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012602]Packet upgrade start...
[00012649]Packet checking...
[00012689]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012730]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012769]Done.
[00012807]Version checking[1]...
[00012900][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012979][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013040][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013099][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013219][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013319][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013418][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013519][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013620][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013761][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013849][17 00][00] v1.1.1.7 -> v1.1.1.7
[00013975][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014040][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014155][01 00][00] v1.23.3419 -> v1.23.3419
[00014194][01 01][00] v1.23.3419 -> v1.23.3419
[00014276][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014318]Packet upgrade cancelled at version checking.
[00012638]========== 2015.08.18 12:39:36. boot(15) ============
[00012681]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012722]Packet upgrade start...
[00012771]Packet checking...
[00012816]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012857]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012896]Done.
[00012939]Version checking[1]...
[00013026][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013106][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013160][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013226][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013349][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013441][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013642][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013737][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013902][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013996][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014116][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014187][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014231][01 00][00] v1.23.3419 -> v1.23.3419
[00014273][01 01][00] v1.23.3419 -> v1.23.3419
[00014322][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014381]Packet upgrade cancelled at version checking.
[00012644]========== 2015.08.18 15:17:25. boot(15) ============
[00012685]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012734]Packet upgrade start...
[00012781]Packet checking...
[00012829]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012873]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012914]Done.
[00012961]Version checking[1]...
[00013031][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013110][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013166][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013241][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013352][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013618][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013706][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013806][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013952][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014037][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014157][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014221][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014269][01 00][00] v1.23.3419 -> v1.23.3419
[00014314][01 01][00] v1.23.3419 -> v1.23.3419
[00014392][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014435]Packet upgrade cancelled at version checking.
[00012606]========== 2015.08.18 20:11:02. boot(15) ============
[00012646]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012687]Packet upgrade start...
[00012733]Packet checking...
[00012775]Packet vlink 01.03.0020 <-> 01.01.0009.
[00012814]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00012855]Done.
[00012989][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013065][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013112][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013180][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013309][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013406][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013496][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013609][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013707][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014503][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014594][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014734][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014793][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014835][01 00][00] v1.23.3419 -> v1.23.3419
[00014877][01 01][00] v1.23.3419 -> v1.23.3419
[00014929][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014968]Packet upgrade cancelled at version checking.
[00012649]========== 2015.08.18 21:39:40. boot(15) ============
[00012693]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00012737]Packet upgrade start...
[00012785]Packet checking...
[00012830]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013009]Done.
[00013053]Version checking[1]...
[00013121][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013201][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013253][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013305][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013447][11 00][00] v1.7.0.0 -> v1.7.0.0
[00013531][12 00][00] v1.8.0.0 -> v1.8.0.0
[00013615][12 01][00] v1.8.0.0 -> v1.8.0.0
[00013697][12 02][00] v1.8.0.0 -> v1.8.0.0
[00013796][12 03][00] v1.8.0.0 -> v1.8.0.0
[00013956][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014051][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014175][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014245][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014292][01 00][00] v1.23.3419 -> v1.23.3419
[00014350][01 01][00] v1.23.3419 -> v1.23.3419
[00014408][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014452]Packet upgrade cancelled at version checking.
[00013186]========== 2015.08.19 14:22:22. boot(15) ============
[00013233]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x90ce2654].
[00013276]Packet upgrade start...
[00013328]Packet checking...
[00013379]Packet vlink 01.03.0020 <-> 01.01.0009.
[00013423]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00013470]Done.
[00013516]Version checking[1]...
[00013596][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013681][03 06][00] v2.2.6.19 -> v2.2.6.19
[00013733][04 00][00] v1.40.0.0 -> v1.40.0.0
[00013807][09 00][00] v1.7.0.3 -> v1.7.0.3
[00013921][11 00][00] v1.7.0.0 -> v1.7.0.0
[00014016][12 00][00] v1.8.0.0 -> v1.8.0.0
[00014115][12 01][00] v1.8.0.0 -> v1.8.0.0
[00014215][12 02][00] v1.8.0.0 -> v1.8.0.0
[00014316][12 03][00] v1.8.0.0 -> v1.8.0.0
[00014509][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014605][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014727][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014787][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014831][01 00][00] v1.23.3419 -> v1.23.3419
[00014875][01 01][00] v1.23.3419 -> v1.23.3419
[00014943][08 00][00] v0.12.0.4 -> v0.12.0.4
[00014986]Packet upgrade cancelled at version checking.
Log.txt for LAST upgrade attempt from 1.3.2 to 1.6.4 :-
[00013232]Done.
[00014481]Done.
[00102788]Done.
[00012798]Done.
[00012793]Done.
[00012976]Done.
[00013792]Done.
[00015140]Done.
[00014270]Done.
[00015646]Done.
[01151298]Done.
[00012718]Done.
[00012728]Done.
[00014088]Done.
[00078704]Done.
[00012743]Done.
[00012745]Done.
[00012859]Done.
[00012831]Done.
[00012769]Done.
[00012896]Done.
[00012914]Done.
[00012855]Done.
[00013009]Done.
[00013470]Done.
[00017405]========== remo-con disconnect. boot(15) ============
[00017450]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x0023d874].
[00017497]Packet upgrade start...
[00017550]Packet checking...
[00017595]Packet vlink 01.06.0040 <-> 01.05.0030.
[00017643]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00017692]Done.
[00017739]Version checking[1]...
[00017822][03 05][00] v34.2.0.9 -> v34.2.0.9
[00017901][03 06][00] v2.2.6.19 -> v2.4.10.7 need upgrade.
[00017954][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00018082][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00018171][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00018271][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00018371][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00018460][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00031006][15 00][00] device not detected.
[00031111][17 00][00] v1.1.1.7 -> v1.1.1.7
[00031252][17 01][00] v1.0.2.7 -> v1.0.2.7
[00031326][19 00][00] v1.0.8.96 -> v1.0.8.96
[00031377][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00031427][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00043974][08 00][00] device not detected.
[00044047][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00044097]Done.
[00046144]Waiting for user confirm...
[00056189]Timeout, start upgrade automatically.
[00056278]Firmware upgrading[1]...
[00069082][01 00] Firmware upgrade start...
[00014240][01 00] Firmware upgrade finished successfully.
[00014288]Done.
[00014334]Packet [C:\P3X_FW_V01.06.0040.bin] resumed, card sn [0x0023d874].
[00014387]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014433]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014480]Version checking[2]...
[00014559][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014640][03 06][00] v2.2.6.19 -> v2.4.10.7 need upgrade.
[00014698][04 00][00] v1.40.0.0 -> v1.41.0.0 need upgrade.
[00014820][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014913][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015093][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015200][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00015308][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00027857][15 00][00] device not detected.
[00027949][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028094][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028164][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028211][01 00][05] v1.26.4315 -> v1.26.4315
[00028262][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00040815][08 00][00] device not detected.
[00040885][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00040933]Done.
[00040981]Firmware upgrading[2]...
[00041145][01 01] Firmware upgrade start...
[00071422][01 01] Firmware upgrade finished successfully.
[00071485][12 00] Firmware upgrade start...
[00148775][12 00] Firmware upgrade finished successfully.
[00148841][12 01] Firmware upgrade start...
[00231859][12 01] Firmware upgrade finished successfully.
[00231922][12 02] Firmware upgrade start...
[00314764][12 02] Firmware upgrade finished successfully.
[00314828][12 03] Firmware upgrade start...
[00397848][12 03] Firmware upgrade finished successfully.
[00397910][11 00] Firmware upgrade start...
[00449736][11 00] Firmware upgrade finished successfully.
[00450022][03 06] Firmware upgrade start...
[00780777][03 06] Firmware upgrade finished successfully.
[00780852][09 00] Firmware upgrade start...
[00834288][09 00] Firmware upgrade finished successfully.
[00834367][04 00] Firmware upgrade start...
[00892721][04 00] Firmware upgrade finished successfully.
[00892766]Done.
[00892815]Version checking[3]...
[00892898][03 05][00] v34.2.0.9 -> v34.2.0.9
[00892977][03 06][05] v2.4.10.7 -> v2.4.10.7
[00893031][04 00][05] v1.41.0.0 -> v1.41.0.0
[00893158][11 00][05] v1.7.15.1 -> v1.7.15.1
[00893257][12 00][05] v1.10.0.0 -> v1.10.0.0
[00893356][12 01][05] v1.10.0.0 -> v1.10.0.0
[00893458][12 02][05] v1.10.0.0 -> v1.10.0.0
[00893557][12 03][05] v1.10.0.0 -> v1.10.0.0
[00906104][15 00][00] device not detected.
[00906272][17 00][00] v1.1.1.7 -> v1.1.1.7
[00906402][17 01][00] v1.0.2.7 -> v1.0.2.7
[00906478][19 00][00] v1.0.8.96 -> v1.0.8.96
[00906533][01 00][05] v1.26.4315 -> v1.26.4315
[00906581][01 01][05] v1.26.4315 -> v1.26.4315
[00919132][08 00][00] device not detected.
[00919198][09 00][05] v2.13.0.0 -> v2.13.0.0
[00919249]Packet upgrade failed at version checking.
[00014712]========== remo-con disconnect. boot(15) ============
[00014767]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x0023d874].
[00014819]Packet upgrade start...
[00014871]Packet checking...
[00014919]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014970]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015018]Done.
[00015067]Version checking[1]...
[00015160][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015260][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015315][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015461][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015568][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015668][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015768][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015868][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028417][15 00][00] device not detected.
[00028528][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028669][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028735][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028784][01 00][00] v1.26.4315 -> v1.26.4315
[00028835][01 01][00] v1.26.4315 -> v1.26.4315
[00041384][08 00][00] device not detected.
[00041454][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041506]Packet upgrade failed at version checking.
[00015907]========== remo-con disconnect. boot(15) ============
[00015960]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x0023d874].
[00016008]Packet upgrade start...
[00016064]Packet checking...
[00016111]Packet vlink 01.04.0010 <-> 01.03.0020.
[00016162]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00016211]Done.
[00016259]Version checking[1]...
[00016341][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016521][03 06][00] v2.4.10.7 -> v2.3.0.13
[00016584][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016659][09 00][00] v2.13.0.0 -> v1.7.0.3
[00016782][11 00][00] v1.7.15.1 -> v1.7.0.0
[00016885][12 00][00] v1.10.0.0 -> v1.10.0.0
[00016985][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017085][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017185][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029735][15 00][00] device not detected.
[00029831][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029965][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030042][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030093][01 00][00] v1.26.4315 -> v1.23.3419
[00030145][01 01][00] v1.26.4315 -> v1.23.3419
[00042695][08 00][00] device not detected.
[00042745]Packet upgrade failed at version checking.
[00014560]========== 2016.01.05 15:24:34. boot(15) ============
[00014612]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x0023d874].
[00014663]Packet upgrade start...
[00014723]Packet checking...
[00014775]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014830]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00014880]Done.
[00014934]Version checking[1]...
[00015020][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015100][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015166][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015244][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015362][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015455][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015555][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015657][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015754][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028308][15 00][00] device not detected.
[00028413][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028549][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028610][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028668][01 00][00] v1.26.4315 -> v1.23.3419
[00028717][01 01][00] v1.26.4315 -> v1.23.3419
[00041270][08 00][00] device not detected.
[00041316]Packet upgrade failed at version checking.
[00014644]========== remo-con disconnect. boot(15) ============
[00014701]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x0023d874].
[00014834]Packet upgrade start...
[00014893]Packet checking...
[00014943]Packet vlink 01.04.0010 <-> 01.03.0020.
[00014996]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015050]Done.
[00015101]Version checking[1]...
[00015185][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015292][03 06][00] v2.4.10.7 -> v2.3.0.13
[00015351][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015430][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015568][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015674][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015779][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015874][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015979][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028532][15 00][00] device not detected.
[00028641][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028780][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028852][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028908][01 00][00] v1.26.4315 -> v1.23.3419
[00028961][01 01][00] v1.26.4315 -> v1.23.3419
[00041513][08 00][00] device not detected.
[00041574]Packet upgrade failed at version checking.
[00016111]========== remo-con disconnect. boot(15) ============
[00016170]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x0023d874].
[00016223]Packet upgrade start...
[00016277]Packet checking...
[00016335]Packet vlink 01.06.0040 <-> 01.05.0030.
[00016386]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00016441]Done.
[00016497]Version checking[1]...
[00016592][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016692][03 06][00] v2.4.10.7 -> v2.4.10.7
[00016753][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016892][11 00][00] v1.7.15.1 -> v1.7.15.1
[00016996][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017096][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017196][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017297][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029852][15 00][00] device not detected.
[00029963][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030097][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030173][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030231][01 00][00] v1.26.4315 -> v1.26.4315
[00030372][01 01][00] v1.26.4315 -> v1.26.4315
[00042925][08 00][00] device not detected.
[00042993][09 00][00] v2.13.0.0 -> v2.13.0.0
[00043055]Packet upgrade failed at version checking.
[00014785]========== remo-con disconnect. boot(15) ============
[00014839]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x0023d874].
[00014894]Packet upgrade start...
[00014952]Packet checking...
[00015004]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015061]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015112]Done.
[00015166]Version checking[1]...
[00015250][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015350][03 06][00] v2.4.10.7 -> v2.2.6.19
[00015408][04 00][00] v1.41.0.0 -> v1.40.0.0
[00015494][09 00][00] v2.13.0.0 -> v1.7.0.3
[00015630][11 00][00] v1.7.15.1 -> v1.7.0.0
[00015730][12 00][00] v1.10.0.0 -> v1.8.0.0
[00015830][12 01][00] v1.10.0.0 -> v1.8.0.0
[00015930][12 02][00] v1.10.0.0 -> v1.8.0.0
[00016030][12 03][00] v1.10.0.0 -> v1.8.0.0
[00028585][15 00][00] device not detected.
[00028675][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028815][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028895][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028953][01 00][00] v1.26.4315 -> v1.23.3419
[00029005][01 01][00] v1.26.4315 -> v1.23.3419
[00041559][08 00][00] device not detected.
[00041609]Packet upgrade failed at version checking.
[00016035]========== remo-con disconnect. boot(15) ============
[00016095]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0x0023d874].
[00016151]Packet upgrade start...
[00016209]Packet checking...
[00016261]Packet vlink 01.04.0010 <-> 01.03.0020.
[00016314]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00016366]Done.
[00016418]Version checking[1]...
[00016521][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016621][03 06][00] v2.4.10.7 -> v2.3.0.13
[00016687][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016755][09 00][00] v2.13.0.0 -> v1.7.0.3
[00016901][11 00][00] v1.7.15.1 -> v1.7.0.0
[00017110][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017210][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017310][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017437][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029991][15 00][00] device not detected.
[00030121][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030266][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030339][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030391][01 00][00] v1.26.4315 -> v1.23.3419
[00030446][01 01][00] v1.26.4315 -> v1.23.3419
[00042999][08 00][00] device not detected.
[00043056]Packet upgrade failed at version checking.
[00016235]========== remo-con disconnect. boot(15) ============
[00016292]Packet [C:\P3X_FW_V01.05.0030.bin] detected, card sn [0x0023d874].
[00016348]Packet upgrade start...
[00016406]Packet checking...
[00016458]Packet vlink 01.05.0030 <-> 01.04.0010.
[00016511]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00016566]Done.
[00016619]Version checking[1]...
[00016707][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016806][03 06][00] v2.4.10.7 -> v2.4.0.5
[00016869][04 00][00] v1.41.0.0 -> v1.41.0.0
[00017006][11 00][00] v1.7.15.1 -> v1.7.0.0
[00017119][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017248][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017355][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017455][12 03][00] v1.10.0.0 -> v1.10.0.0
[00030009][15 00][00] device not detected.
[00030116][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030255][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030326][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030386][01 00][00] v1.26.4315 -> v1.26.4315
[00030444][01 01][00] v1.26.4315 -> v1.26.4315
[00042996][08 00][00] device not detected.
[00043067][09 00][00] v2.13.0.0 -> v2.13.0.0
[00043125]Packet upgrade failed at version checking.
[00016157]========== remo-con disconnect. boot(15) ============
[00016214]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x0023d874].
[00016269]Packet upgrade start...
[00016328]Packet checking...
[00016379]Packet vlink 01.06.0040 <-> 01.05.0030.
[00016431]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00016561]Done.
[00016620]Version checking[1]...
[00016718][03 05][00] v34.2.0.9 -> v34.2.0.9
[00016797][03 06][00] v2.4.10.7 -> v2.4.10.7
[00016859][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016998][11 00][00] v1.7.15.1 -> v1.7.15.1
[00017106][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017207][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017307][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017406][12 03][00] v1.10.0.0 -> v1.10.0.0
[00029967][15 00][00] device not detected.
[00030067][17 00][00] v1.1.1.7 -> v1.1.1.7
[00030207][17 01][00] v1.0.2.7 -> v1.0.2.7
[00030283][19 00][00] v1.0.8.96 -> v1.0.8.96
[00030337][01 00][00] v1.26.4315 -> v1.26.4315
[00030390][01 01][00] v1.26.4315 -> v1.26.4315
[00042949][08 00][00] device not detected.
[00043023][09 00][00] v2.13.0.0 -> v2.13.0.0
[00043079]Packet upgrade failed at version checking.
[00014770]========== remo-con disconnect. boot(15) ============
[00014823]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x0023d874].
[00014881]Packet upgrade start...
[00014942]Packet checking...
[00014996]Packet vlink 01.06.0040 <-> 01.05.0030.
[00015050]Record vlink 01.03.0020 <-> 01.01.0009 (flow = 0).
[00015104]Done.
[00015159]Version checking[1]...
[00015257][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015338][03 06][00] v2.4.10.7 -> v2.4.10.7
[00015398][04 00][00] v1.41.0.0 -> v1.41.0.0
[00015517][11 00][00] v1.7.15.1 -> v1.7.15.1
[00015606][12 00][00] v1.10.0.0 -> v1.10.0.0
[00015731][12 01][00] v1.10.0.0 -> v1.10.0.0
[00015831][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015932][12 03][00] v1.10.0.0 -> v1.10.0.0
[00028487][15 00][00] device not detected.
[00028583][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028732][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028801][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028860][01 00][00] v1.26.4315 -> v1.26.4315
[00028914][01 01][00] v1.26.4315 -> v1.26.4315
[00041469][08 00][00] device not detected.
[00041541][09 00][00] v2.13.0.0 -> v2.13.0.0
[00041601]Packet upgrade failed at version checking.
2016-1-8
Chris36
DJI-Patrick Posted at 2016-1-6 08:32
Please confirm you've downloaded the right firmware : http://dl.djicdn.com/downloads/phantom_3/P3X ...
Hi, Patrick and Ken,  after carrying out the steps described in my last reply, I had a closer look at the content of the Log.txt file.  It seems that all listings which failed have two "problems" in common  viz.  all report "Device not detected" for items identified as '0800' and '1500.'
1. Are these hardware or software/FW items?
2. What are they and does either or both indicate clearly why the updates failed?
3. Can they be 'fixed' by some software procedure or, if hardware, does this mean repair can only be done by returning the aircraft to my Dealer or DJI?
4. Can the RC problem be resolved at the same time?
I look forward to your response(s).
Kind regards,
Chris36
2016-1-10
DJI-Patrick
Chris36 Posted at 2016-1-11 03:32
Hi, Patrick and Ken,  after carrying out the steps described in my last reply, I had a closer look ...
If the "0800" and "1500" can't be detected , please contact support center to get a RMA . http://www.dji.com/support
2016-1-10
Chris36
Chris36 Posted at 2016-1-6 00:00
Sorry, not yet  -  I'm ever hopeful but not very confident.  I'll post any useful info as soon as  ...
I had to return my P3P and RC for repair.  The conclusion by DJI Netherlands was that use of too long screws to fasten prop guard quick disconnect parts resulted in damage to two of the motors which due to excessive vibration also caused cracks to the lower casing.  Two motors and the lower casing were replaced but designated as "damage caused by pilot" were not covered by the warranty,  The fault in the RC was apparently in the USB circuitry and was sufficiently severe that the RC was completely replaced under warranty.
I will advise supplier of the quick disconnect prop guards about the screws which they specially supplied with the guards, supposedly of the correct length to avoid this already known possibility.  It seems they were still too long for my P3P!
Regards to all who helped.  My P3P with new RC has been returned fully updated and appears to be in good order though I have not yet flown it.
Chris36
2016-2-14
