Created For | High-level aerial photography and cinematography | Beginners & First-time pilots | High-level aerial photography and cinematography |
In The Box | 1. Phantom 3 Professional or Advanced Aircraft
2. Phantom 3 Pro./Adv. Remote Controller
3. 3-Axis Camera Stabilization Gimbal
4. Built-in Camera Captures 4K (Pro) or 2.7K (Adv) video & 12.4M Photos
5. DJI Lightbridge Video Downlink, 3.1mi (5Km) range
6. 4S 15.2V 4480mAh Intelligent Flight Battery
7. Four Pairs of Propellers | 1. Phantom3 Aircraft
2. Phantom 3 Standard Remote Controller
4. Built-in Camera Captures 2.7 K video & 12MP Photo
5. 2.4G WiFi Video Downlink, 1km range
7. Four Pairs of Propellers | 1. Phantom 3 4K Aircraft
2. Phantom 3 4K Remote Controller
4. Built-in Camera Captures 4K video & 12.4M Photos
5. 2.4G WiFi Video Downlink, 1.2km range
AIRCRAFT |
Diagonal Size (Excluding Propellers) | 350 mm | 350 mm | 350 mm |
Weight: (Including Battery And Propellers) | 1280 g | 1216 g | 1280 g |
LiPo Battery | 4S, 15.2V, 68WH 4480mAh Intelligent Flight Battery | 4S, 15.2V, 68WH 4480mAh Intelligent Flight Battery | 4S, 15.2V, 68WH 4480mAh Intelligent Flight Battery |
Charger | Remote and Flight Battery Charger
Professional: 100W Charger
Advanced: 57W Charger | 57W Flight Battery Charger
Remote is charged via USB | 57W Flight Battery Charger |
Flight Time | About 23 mins | About 25 mins | About 25 mins |
Max. Flight Speed | 16m/s | 16m/s | 16m/s |
POSITIONING MODULE |
Outdoors Positioning Module | GPS+GLONASS Dual Positioning Module | GPS Positioning Module | GPS Positioning Module |
Vision Positioning Module | Vision Positioning System with ultrasonic sensors (Position holding without GPS) | No | Vision Positioning System with ultrasonic sensors (Position holding without GPS) |
Hover Accuracy | Vertical: +/- 0.1 m (when Vision Positioning is active) or +/- 0.5 m
Horizontal: +/- 1.5 m | Vertical: +/- 0.5 m
Horizontal: +/- 1.5 m | Vertical: +/- 0.1 m (when Vision Positioning is active) or +/- 0.5 m
CAMERA |
Sensor | Sony Exmor R BSI 1/2.3", Effective pixels 12.4M (Total pixels 12.76M) | Panasonic Smart FSI 1/2.3", Effective pixels 12M (Total pixels 12M) | Sony Exmor R BSI 1/2.3", Effective pixels 12.4M (Total pixels 12.76M) |
Video Resolution | Phantom 3 Professional
UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
FHD: 1920x1080p 24/25/30/48/50/60
HD: 1280x720p 24/25/30/48/50/60
Phantom 3 Advanced
2.7K: 2704x1520p 24/25/30 (29.97)
HD: 1280x720p 24/25/30/48/50/60 | 2.7Kp30(29.997)(2704*1520)
HD: 1280x720p 24/25/30/48/50/60 | UHD: 4096x2160p 24/25, 3840x2160p 24/25/30
Max. Image Size | 4000 x 3000 | 4000 x 3000 | 4000 x 3000 |
Lens | FOV 94° 20 mm (35 mm format equivalent) f/2.8
focus at ∞ | FOV 94° 20 mm (35 mm format equivalent) f/2.8
focus at ∞ |
Filter Ring | Yes, Removable to Allow for ND Filters | No | Yes, Removable to Allow for ND Filters |
REMOTE CONTROLLER & VIDEO DOWNLINK |
Dedicated Buttons On Remote | Return Home Button | Yes | Return Home Switch | Return Home Switch | Video Recording Button | Yes | No | Yes | Shutter Button | Yes | No | Yes | Playback Button | Yes | No | Yes | Flight Mode Switch | Yes | Yes | Yes | Gimbal Dial | Yes | Yes | Yes | 2 Dedicated Customizable buttons | Yes | No | Yes |
Max Transmission Distance | CE: 3500 m
FCC: 5000 m (unobstructed and no interference) | CE:500m
FCC:1000m (outdoors and unobstructed) | CE:500m;
FCC:1200m (outdoors and unobstructed) |
Video Transmission System | Built-in DJI Lightbridge Video Downlink | Built-in DJI WiFi Video Downlink | Built-in DJI WiFi Video Downlink |
Video Transmission Distance | CE: 3500 m
FCC: 5000 m (unobstructed and no interference) | CE: 500m
FCC: 1000m (outdoors and unobstructed, flight altitude 120m) | CE: 500m ;
FCC: 1200m(outdoors and unobstructed, flight altitude 120m) |
Max. Video Bitrate | Phantom 3 Professional:10Mbps
Phantom 3 Advanced:2Mbps | 2Mbps | 2M bps |
Max FPV Preview Quality: | HD 720P @ 30fps (depending on conditions and mobile device) | HD 720P @ 30fps (depending on conditions and mobile device) | SD 480P @ 30fps |
APP |
Mobile App | DJI GO | DJI GO | DJI GO |
Intelligent Flight Modes | Follow Me
Point of Interest
Waypoints
Course Lock
Home Lock | Follow Me
Point of Interest
Waypoints
Course Lock
Point of Interest
Waypoints
Course Lock
Home Lock |
