Fink
I have this exact same issue - I will try resetting the gimbal settings as Ken has suggested to see if that resolves it.
Some things to note on mine in case it helps others:
1. If I manually swing the camera around to the maxed out clockwise position and then power it on, it starts up pointing in the correct orientation after it does the calibration routine/dance.
2. If, after powering up it is still stuck at the 45 degree, maxed out clockwise position, resetting the gimbal yaw brings it back straight again. |
