Geebax
Yes, many of use do balance our props, the general concensus is that the DuBro balancer is the best one for the job, and you should also order their double-ended balancing shaft as well, as the props on the Phantom are blind holes and need a special shaft.
You will fond several threads on the subject if you search the forum. It is also generally found that the DJI props are fairly well balanced, but can be improved. |
