GTDrone
Flight distance : 2197703 ft
Guatemala
yes , i did a test on a top of 3km altitude mountain that iit was a really open area , and i only get 500 meters of range , i try the windsurf for the antenna i only get 200 meters more , it really helps but i think that may be there is something better outside to get more range with the standard
or maybe a way to change to FCC, is really bad that DJI set CE by default if you are outside of USA, i mean my country is really close to USA so we use almost all the regulation that they use in USA , and all the people here that own a p2v+ fly using FCC geting a lot better range that the p3s, so may be later they can allow us to change it to FCC
i just want to know if there is someting that we can do to get better range , i saw some videos about people that add lightbridge to the p2v+ maybe we can found something like that or at least an antenna booster |
