Strong Arm Reinforcement Plates
3490 32 2016-1-12
Cabralkev
Flight distance : 1997861 ft
Are they worth it? I had them on, but took them off recently because I thought I was going to send my Phantom in for repair. Should I reinstall them back on or nah?
2016-1-12
Jkeller84
Flight distance : 396955 ft
A. Leaving them on could protect from possible shell cracks. I don't know this to be true, but that is what they claim.
B. Taking them of could result in possible shell cracks.
I think you can make that call yourself.
2016-1-12
Jkeller84
Also, I just realized that I might have sounded like a jerk in that response. Not my intention. I am just helping you rationalize. I personally do not use them, but in 4 Phantoms I have not once had a shell crack. I have seen pictures of folks that do, so if I already had the reinforcements, I would probably use them anyway.
2016-1-12
Cabralkev
No worries. I had them installed but took them off. Just not sure if I should install them back on or leave it as is. Not sure if they do what they're advertised to do . I would assume it would add extra strength under the motors.
2016-1-12
Rnfaust
Flight distance : 734938 ft
Cabralkev Posted at 2016-1-12 22:17
No worries. I had them installed but took them off. Just not sure if I should install them back on o ...
I'm using them and feel they should distribute the loads around the motors significantly. I'm pretty certain they will prevent cracking in that area.
I did see another brand available that also looks good. But I know the Strong Arms and their new screws fit correctly.
BTW: I wouldn't use the available prop protectors because I'm sure they would add additional stress to the shell. Just don't fly inside and you really don't need them outside anyway. (IMO)
2016-1-12
Cabralkev
Rnfaust Posted at 2016-1-13 00:39
I'm using them and feel they should distribute the loads around the motors significantly. I'm pret ...
You're using the strong arms as well? I got the white ones. Did you use nail polish for loctite? I did with mine it worked well. I suppose I will install them again
2016-1-12
SlowPoke
Flight distance : 26381 ft
What does strong arm reinforcement plates look like?
2016-1-12
Cabralkev
SlowPoke Posted at 2016-1-13 01:35
This is what we are talking about:
2016-1-13
Rnfaust
Cabralkev Posted at 2016-1-12 23:25
You're using the strong arms as well? I got the white ones. Did you use nail polish for loctite? I  ...
I did use a little bit of blue medium Loctite on the motor screws. It says it won't harm plastic.
I got the black ones to match my painted P3A. I don't think there is any downside to using them.
2016-1-13
Rnfaust
SlowPoke Posted at 2016-1-12 23:35
Look at:
http://www.uavbits.net/collectio ... einforcement-plates
I've seen another brand as well, but this is what I use. Simple concept and apparently very effective. I'm happy
2016-1-13
Cabralkev
I'll install them tonight. We are suppose to tighten the screws until 'snug' right? Not over tighten it by torquing
2016-1-13
Cabralkev
Rnfaust Posted at 2016-1-13 11:01
Look at:
http://www.uavbits.net/collections/motor-reinforcement-plates/products/strong-arm-reinfor ...
How long have you had your Strong Arms installed for?
2016-1-13
nrechtman
Flight distance : 1555344 ft
Cabralkev Posted at 2016-1-13 19:28
can you repost the pic, its blank
2016-1-14
Cabralkev
2016-1-15
mariano76
Flight distance : 509196 ft
For me it's better to balance propellers instead of using reinforcement plates, I think dji should include in every phantom a balancing kit as preventive maintenance
2016-1-15
greenbean
Flight distance : 84783 ft
Cabralkev Posted at 2016-1-13 00:17
I wouldn't use nail polish.....don't know for sure but I think the shells are high density polystyrene and nail polish does play nice with it
2016-1-15
Flight Raptor
Flight distance : 3014675 ft
greenbean Posted at 2016-1-15 10:46
I wouldn't use nail polish.....don't know for sure but I think the shells are high density polysty ...
I think you meant to say, "...does NOT play nice with it"
2016-1-15
Cabralkev
I heard to use nail polish instead of blue loctite. What would nail polish do to the plastic then? I know blue loctite eats at the plastic.
2016-1-15
Cabralkev
Also I was told to use nail polish as threadlock. It's safer than blue loctite.
2016-1-15
Rnfaust
Cabralkev Posted at 2016-1-15 15:03
Don't put anything on the 2 screws that anchor to plastic - the new plates work as lock washers. The 4 center screws go into the metal motor flanges so Loctite is appropriate. You don't need much-that's for sure.
2016-1-15
Rnfaust
mariano76 Posted at 2016-1-15 06:40
For me it's better to balance propellers instead of using reinforcement plates, I think dji should i ...
Either/or - both is even better.
2016-1-15
Rnfaust
Cabralkev Posted at 2016-1-13 23:36
I installed them 3 months ago as a preventative measure. I had an unfortunate crash the first month of flying which bent the motor end of the shell. I used a heat gun to straighten it. There was no adverse affect and no cracks. I felt the Strong Arms might be a good addition after my repair.
Still no cracks - guess I got a good one!
2016-1-15
Cabralkev
Rnfaust Posted at 2016-1-15 18:32
Don't put anything on the 2 screws that anchor to plastic - the new plates work as lock washers. Th ...
Is nail polish bad for the plastic? I used it though. Hopefully it doesn't eat at the plastic. I heard blue loctite will
2016-1-15
Ryano305
The person who makes the strong arms suggest nail polish and I used it on mine and haven't had any issues
2016-1-15
Rnfaust
Cabralkev Posted at 2016-1-15 17:11
Is nail polish bad for the plastic? I used it though. Hopefully it doesn't eat at the plastic. I h ...
UAV Bits (StrongArm) recommends nail polish. I use nothing on the plastic connections and Loctite 242 on the metal motor screws (not much).
Loctite says on their website not to use it on plastic (I believe I complied by using very little at the end of the motor screws and wiping off the excess.)
They make Loctite 425 for metal and plastic, but it's crazy expensive. Probably for industrial use. DJI does put some type of blue locker on their screws though - maybe it's the 425.
2016-1-15
AG0N-Gary
Flight distance : 700846 ft
I used blue Loctite.  DJI seems to use it also.  All of the screws I removed had it (or something that looked like it) on the threads.
2016-1-15
Cabralkev
Rnfaust Posted at 2016-1-15 21:07
UAV Bits (StrongArm) recommends nail polish. I use nothing on the plastic connections and Loctite  ...
Yeah I was going to mention that. UAV Bits suggests using nail polish for thread locking when installing their product. That's what I did, applied some white nail polish on the tips of the screws. Then screwed them in. I removed the plates a month ago though, haven't got around installing them back on. So when I put the factory screws back on, I never used any nail polish on them. Just left it as is. Noticed some blue loctite on the factory screws though from DJI. Maybe they're pre-treated blue loctite?
I assume if the nail polish did any damage, the factory screws wouldn't be able to screw in? It would keep spinning right?
2016-1-15
Rnfaust
Cabralkev Posted at 2016-1-15 19:48
Yeah I was going to mention that. UAV Bits suggests using nail polish for thread locking when inst ...
You're the test case. Keep an eye on them.
I really think the ones that matter are the motor screws and they screw into metal. They are also the ones most benefitting from Strong Arms and the ones you can use Loctite on (IMO).
2016-1-15
Cabralkev
Rnfaust Posted at 2016-1-15 22:04
I really think the ones that matter are the motor screw ...
I feel like a ginnie pig lol. Well the factory screws tighten fine. No issues. So I suppose the threads in the plastic didn't get eaten away by the nail polish.
2016-1-15
goldchucker.wav
Flight distance : 512 ft
Rnfaust Posted at 2016-1-15 15:46
I installed them 3 months ago as a preventative measure. I had an unfortunate crash the first mont ...
I tried to remove the two shell screws on one of the arms on my dji P Std. but none of my 2mm drivers will fit.  However ,the 2mm drivers I have will fit the motor screws.  I also tried the next size down from 2mm and it is too small.  Any suggestions on what size driver is required for the shell screws?
Thank you.
Chuck
2016-1-22
goldchucker.wav
goldchucker.wav Posted at 2016-1-22 16:02
I tried to remove the two shell screws on one of the arms on my dji P Std. but none of my 2mm driv ...
I found out that the screws in question are Torx #8 so I orderd the proper driver.
2016-1-22
Elmer Fudd
Cabralkev Posted at 2016-1-15 22:12
I feel like a ginnie pig lol. Well the factory screws tighten fine. No issues. So I suppose the th ...
The screws that hold the shell together are threaded into a metal insert embedded into the plastic.
2016-1-22
goldchucker.wav
Elmer Fudd Posted at 2016-1-22 19:41
The screws that hold the shell together are threaded into a metal insert embedded into the plastic ...
Thank you.  That's good to know as plastic is easily stripped out.
Chuck
2016-1-23
