Phantom 3 pro firmware upgrade problem
3391 28 2016-1-12
mrnvldz
Flight distance : 5256 ft
Hello Everybody, I'm trying to upgrade the firmware from 1.5.0030 to 1.6.0040 on my p3p but when I insert the micro sd card and turn on the unit the phantom does nothing, just the flashing yellow lights but no beeping sounds as if the firmware wasn't in the card... when I bought it back in december did the firmware upgrade with out problems, the phantom is working fine right now, but in the app says that I need to update the firmware on the unit and batteries, any ideas?
yes the controller is off while trying the update, and the file is unzipped too, I'm doing it  the exactly same way as I did back in december but for some reason is not detecting the firmware in the card and yes I try with 3 different cards, formatting the cards and nothing.
any help will be appreciated, thank you.
2016-1-12
Cetaman
Flight distance : 2528264 ft
Aloha mrnvldz,
     This is interesting.  Even though the update is for the P3, there are three computers involved here in the network, your tablet, the Remote Control and the P3.  If nothing is happening, it may be an indication that the RC or the DJI Go app also need updating.  The P3 will not update unless the version numbers of the RC and DJI Go app allow it to update and those version numbers are recorded in the P3 data files.  There were numerous updates in December.  What does the "About" page say your three versions are?
Aloha and Drone On!
2016-1-12
DJI-Patrick
Please format the SD card via DJI Go App and try upgrade again . If the updating failed , please post the upgrade log in the HIDDEN FOLDER of the SD card here. The file name should be: P3_FW_LOG_AB.txt
To find the right file, please try to access the Hidden Folder of the SD card by this way:
For Windows: http://windows.microsoft.com/en- ... den-files=windows-7
For MAC: http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/
2016-1-13
mrnvldz
Cetaman Posted at 2016-1-12 23:41
Aloha mrnvldz,
     This is interesting.  Even though the update is for the P3, there are three com ...
App 2.5.1
Aircraft 1.5.30
RC 1.5.70
2016-1-17
Cetaman
mrnvldz Posted at 2016-1-17 19:36
App 2.5.1
Aircraft 1.5.30
RC 1.5.70
Aloha mrnvidz,
     As DJI-Patrick indicated:
"Please format the SD card via DJI Go App and try upgrade again."
This means starting up the RC and P3 and formatting the micro SD card with the pre-flight checklist page where it asks if you want to format the SD card.
"If the updating failed , please post the upgrade log in the HIDDEN FOLDER of the SD card here. The file name should be: P3_FW_LOG_AB.txt
For MAC: http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/"
     DJI-Patrick usually has it right on.
Aloha and Drone On!
2016-1-18
mrnvldz
Cetaman Posted at 2016-1-18 01:34
Aloha mrnvidz,
when I turn on the P3 It doesn't make any sounds as if the firmware is not in the card and the upgrade  never start.
2016-1-18
mrnvldz
DJI-Patrick Posted at 2016-1-13 01:04
Please format the SD card via DJI Go App and try upgrade again . If the updating failed , please pos ...
The P3 doesn't make any sounds or beeps as if the firmware wasn't in the card.
2016-1-18
[RCG]Balthazar
Flight distance : 475371 ft
Norway
SD Card
mrnvldz Posted at 2016-1-18 19:16
I'm not Apple Savy but it seems like theres a lot on your card.
Try it with only the .bin file.
2016-1-18
mrnvldz
[RCG]Balthazar Posted at 2016-1-18 10:31
I did, this is only the hidden files in the card folder.
2016-1-18
[RCG]Balthazar
Norway
mrnvldz Posted at 2016-1-18 20:02
Ok because if it was a windows computer the address in your screenshot looks like
Untitled/MISC/P3X_FW_V01.06.0040-4.bin
When it should be
Untitled/P3X_FW_V01.06.0040-4.bin
(If your SD Card is named Untitled)
2016-1-18
DJI-Patrick
mrnvldz Posted at 2016-1-19 02:08
when I turn on the P3 It doesn't make any sounds as if the firmware is not in the card and the upgr ...
Please open that LOG file . And check if there's a text file .
2016-1-19
Cetaman
mrnvldz Posted at 2016-1-18 09:02
Aloha mrnvldz,
     There is your problem.  Your .bin file is in a folder.  The .bin file has to be in the root directory.  Balthasar is pointing that out.  Fix it like Balthazar is pointing out and try it.  It should work.
Aloha and Drone On!
2016-1-19
RedHotPoker
Flight distance : 165105 ft
Remember when I had that same issue, and couldn't figure it out for about one day.
Once the sole bin file was loaded into the root of the micro sd card, it was easy going, and the update began immediately after placing it into the gimbal.
Open the zipped file and extract only that bin file. Leave behind the folder, envelope or whatever the transport holder of zipped files is called. ;-)
After you get onto the hang of updates, it becomes an enjoyable experience. I look forward to all of mine...
RedHotPoker
2016-1-19
mrnvldz
Cetaman Posted at 2016-1-19 02:38
Aloha mrnvldz,
     There is your problem.  Your .bin file is in a folder.  The .bin file has to  ...
mmmm, not sure If I understand but I think that my .bin its not in a folder as you can see in the screen shoot, is in the root directory but not inside the DCIM folder, but I can be totally wrong.   try it that way and didn't work.
ok second try is opening that bin file like this   and   both the .bin and .bin.cpgz files and nothing... then I try with only the .bin.cpgz file and nothing... so I don't understand why I was able to do the update back in december when I bought the P3 using the first method and I can't right now,(by the way same problem with my inspire 1...) I did the firmware upgrade on both of them but now I can't, out of ideas now...
2016-1-19
mrnvldz
RedHotPoker Posted at 2016-1-19 03:37
Once the sole bi ...
can you please  check the screen shoots that I post and tell me if they look right to you. thank you.
2016-1-19
mrnvldz
DJI-Patrick Posted at 2016-1-19 01:46
I cannot open that LOG file there is nothing inside these are the hidden files and only the DCIM folder and the .bin file are in the card and as you can see the .bin file is not inside any folder is in the root directory.
2016-1-19
rreindl
Flight distance : 6491926 ft
mrnvldz Posted at 2016-1-19 14:31
I cannot open that LOG file there is nothing inside these are the hidden files and only the DCIM f ...
Its in the correct location but what is the -5 in the file name? Mine does not have that.
2016-1-19
mrnvldz
rreindl Posted at 2016-1-19 12:41
I think is the number of times that the file have been downloaded to my computer... because I downloaded one more time and the latest file says -6 and the one before -4
2016-1-19
DJI-Ken
Flight distance : 1515312 ft
mrnvldz Posted at 2016-1-20 04:31
I don't know what the -5 is on the Bin file. format the SD card again and download directly from the Phantom3 Pro page. http://www.dji.com/product/phantom-3-pro/info#downloads
Start the firmware update again, if unsuccessful here's the instructions on viewing the hidden files.
Windows system :
Mac system :
2016-1-19
mrnvldz
OK I DID IT !!! , what I did was to rename the file from  P3X_FW_V01.06.0040-5.bin  to P3X_FW_V01.06.0040.bin and voila... I just remove the -5 from the name.
and the firmware update was a success...
THANK YOU  to all of you guys, the help was appreciated, (good eye rreindl).
now let's try that on my inspire...
2016-1-19
mrnvldz
good eye, thank you.
2016-1-19
mrnvldz
DJI-Ken Posted at 2016-1-19 13:13
I don't know what the -5 is on the Bin file. format the SD card again and download directly from t ...
problem solved, thank you.
2016-1-19
mrnvldz
Aloha mrnvldz,
problem is fix, thank you.
2016-1-19
mrnvldz
[RCG]Balthazar Posted at 2016-1-18 11:07
Untitled/MISC/P3 ...
no more problem, thank you.
2016-1-19
DJI-Ken
mrnvldz Posted at 2016-1-20 06:27
great, what was it? After you downloaded a clean firmware it worked correct?
2016-1-19
[RCG]Balthazar
Norway
File Name
DJI-Ken Posted at 2016-1-19 23:32
It was the apple download counter -5 (he tried to download it 5 times to the same location)
Might have catched that if it was a windows PC as it would have added (5) to the file name
Great learning and thanks for letting everybody help!
2016-1-19
DJI-Ken
[RCG]Balthazar Posted at 2016-1-20 06:52
Might  ...
Ahhh, good to know.
2016-1-19
mrnvldz
like Balthazar said it, that was the problem. by the way I just update the inspire 1 with out any problems.
one more time Thank you guys.
2016-1-19
DJI-Patrick
Good to know !
2016-1-19
