DJI OEM charger options.
371 3 2016-1-14
Dacon Productio
I have a P3P drone and looking to shorten the charging time.
Is the 4 batt charger for Inspire also compatible with P3P type batteries?
If I get this type, can I use it to charge P3P batts?
http://www.bhphotovideo.com/c/pr ... r.html/prm/alsVwDtl
or I have to get ONLY this type?
DJI please help with info. Thanks.
2016-1-14
Geebax
Neither of these devices is actually a charger, they are called hubs, you still use the standard DJI charger but plug it into the hub and it then sequentially charges up to 4 batteries. It does not charge the battery any faster, it simply automates the procedure so you do not have to manually change batteries as you do with the standard charger.
And there is no advantage in purchasing the model for the Inspire as it also uses the supplied charger as well. Besides, the Inspire uses a 22.5 volt battery whereas the Phantom uses a 15.5 volt battery. The charges are therefore not interchangeable.
2016-1-14
Dacon Productio
Got it, that is the info I was looking for. Thank you.
B&H you get an order....
2016-1-15
DJI-Ken
Flight distance : 1515312 ft
Dacon Productio Posted at 2016-1-16 00:11
You can also order form DJI.com. The shipping warehouse is in California.
2016-1-15
