martin94b
Hi bornish,
don´t really understand why you want to "extend" a mono track to virtual stereo, but hey...
There are many sound effects available which you can try, maybe even combining them. Results obviously depend on the recorded material, so if you have speech, music, ambient noise.... most likely you´ll have to experience quite a bit before you get satisfying resuilts for each recording material.
- First thing pops up in my mind is a simple stereo chorus effect. Might work well for vocals.
- Also just a little bit of stereo reverb might serve your needs, while it´s also adding the impression of "room" (when you´re recording with Osmo you get a "dry" recording. While usually about 90% of sound which hits your ear has been reflected before, the reflections / reverb add very much to our listening experience.). Try playing around with "Early reflection" and other parameters of that effect. Don´t add too much though. Don´t know why you think they sound fake - they can sound fake, but only if you use parameters not fitting your material / needs...
- Then there´s a bunch of so called psycho-accoustic effects available, e.g. exciter (which add some harmonics leading to a more clear / crisp sound, especially for vocals) or enhancer like the old Behringer Ultrafex (frequency dependent phase shift) which also generate a stereo signal, usually with quite some parameters to adjust the "stereo wideness" just as required. They not only "virtually produce stereo", but they als improve the sound quality just as mentioned - more crisp, more (a)live...
But do not expect true stereo impression - obviously you cannot create a true stereo signal from just a mono track... |
