RC stuck on old firmware (1.2.0.17)
2044 9 2016-1-16
rmracer
Flight distance : 682776 ft
Hello, I am trying to update the RC transmitter but it will not accept any new firmware. Every time I attempt the update the results file says
Result: Abort
The firmware on the SD card is identical to or older than the current firmware on the remote controller.
The current firmware on the controller is 1.2.0.17
I have tried several versons of the firmware and also the reset firmware. Nothing works. I have two transmitters and the one updated just fine but the other will not. Any Ideas? Thanks
2016-1-16
rmracer
I noticed one more thing. The transmitter that I was able to update is a model GL658C and the one I am having the issue with is a GL658A, not sure if that matters
2016-1-16
sthuemmel
Flight distance : 1749321 ft
rmracer@aol.com Posted at 2016-1-16 19:48
I noticed one more thing. The transmitter that I was able to update is a model GL658C and the one I  ...
What version firmware are you trying to update to?  What version is on the Inspire?
What version is on your RC?  Is this the Master RC or Slave?
Have you done this reset.....
I got this from TE
Delete the App,  Reset the RC, then reinstall the App. This is a known issue with v2.4.3.
First - Delete the App
Second - Reset the RC, Please press C1+C2+Shutter (Video on the left side) at the same time, turn off and turn on the RC without releasing these buttons. After resetting, the indicator of RC should be Red.
Please reset master and slave if using dual op.
This procedure resets the output board..
Third -  then reinstall the App. This is a known issue with v2.4.3.
2016-1-16
rmracer
I am trying to upgrade to  v1.3.0.60 (rc version 1.5.70) It is currently on version 1.2.0.17. The transmitter is the slave tx but I have made it the master but it will still not update. It works fine and binds I just cant update the firmware. I tried the reset procedure but it did not work. Thanks
2016-1-17
sthuemmel
rmracer@aol.com Posted at 2016-1-17 10:15
I am trying to upgrade to  v1.3.0.60 (rc version 1.5.70) It is currently on version 1.2.0.17. The tr ...
Does the DJI APP display video?
2016-1-17
Machoman
Flight distance : 1036959 ft
Austria
rmracer@aol.com Posted at 2016-1-17 01:48
The C is much better and has 5 dbm more power output and much more range - at least if the A meets official specs.............
Send the A to DJI for replacment if you are lucky they send you a C back.
2016-1-17
rmracer
sthuemmel Posted at 2016-1-17 10:29
Yes it does. Everything works fine I am just unable to update the RC firmware on the A model transmitter. Is that a problem with that model? The C model updated just fine.
2016-1-17
sthuemmel
rmracer@aol.com Posted at 2016-1-17 22:38
Yes it does. Everything works fine I am just unable to update the RC firmware on the A model trans ...
Because you are at 1.2.70, you need to upgrade to 1.3 via USB.  1.3 is where DJI changed and makes all the updates from the IPAD.  Copy the 1.3 .bin file on the USB, turn on RC only for the upgrade.   You can go to the DJI website and look at the release notes and see what I am talking about.   It is under 1.3 upgrade in the Notice section.
Hopefully this will solve your problem.
2016-1-18
rmracer
sthuemmel Posted at 2016-1-18 16:58
Because you are at 1.2.70, you need to upgrade to 1.3 via USB.  1.3 is where DJI changed and makes ...
That fixed it. Apparently you cant jump from 1.2.70 right to 1.6.0. You must go to 1.3.0 first. Thanks very much
2016-1-19
DJI-Ken
Flight distance : 1515312 ft
rmracer@aol.com Posted at 2016-1-20 06:15
That fixed it. Apparently you cant jump from 1.2.70 right to 1.6.0. You must go to 1.3.0 first. Th ...
Correct, 1.3 has the controller update and you need to stop there before going to 1.5 or 1.6.
2016-1-19
