captdkp
Flight distance : 4521345 ft
Thank you for your time. I guess I am not explaining my problem very well. After the update, I turned the RC and Inspire off to get the card out to reformat it to get ready for a flight. Once that was done, I re-inserted the SD card into the camera and turned on the aircraft. From that point to the present time, no matter what battery I use, I turn it on and the aircraft beeps; not the beeping sequence for updating but beep beep beep beep beep beep beep beep beep for as long as I let it go. Did it twice yesterday once for 10 minutes and the other for 20 minutes. Still, when I turn it on it will beep for as long as I let it. No sequence to the beeping; just beep after beep after beep after beep and on and on and on and on . . . . .
Hope I have explained it better. |
