GB44
Flight distance : 343848 ft
Shepard,
I think you should check the RTH feature.
When operating commercially in the UK, you are required to have a safety feature and to test it. If you haven't tested it, how do you know it is functioning properly and could rely on it in an emergency. As part of commercial operators manual, the ability and use of a RTH function is very important. When you get a firmware update you are required to ensure the aircraft is fully airworthy and ready for commercial operations. If you dont test it and confirm the aircraft is good to go, you cant demonstrate that you have a fully operational aircraft or that it is safe for use. This is the same advice I would advocate for any hobyyist pilot using any UAV.
It is a very worthy bit of technology, embrace it and use it. Check it frequently, especially after each and every firmware update so you know your aircraft is fully airworthy and safe to operate. |
