DJI-Patrick
Dear Sir,
As you can see in the invoice, the main problems are the main controller board and camera component, but there are also shell components and a repair service charge. However, you only changed one part, so the problems with the other parts were not solved. So safe and stable flight is not guaranteed.
We've analyzed your case and found out that the aircraft crashed because you didn't set a proper RTH height, we also can see it from the video you posted. Aircraft can't be covered by warranty in the case of pilot error.
Now you have made a choice of fixing the drone by yourself with second hand parts, which voids your warranty.
All in all, I'm glad to see your drone will be in the air again.
