P3S return to home
634 8 2016-1-23
nabzo
Flight distance : 353310 ft
South Africa
Hi all this my be a stupid question but i want to knpw before i do some thing wrong
When starting up to save home location must o save the remote home location or aircraft home location ?
Reason i asking is because when i hit the auto take off. I fly around and when i click he "H" on the go app it just decends where ever it is and lands but before i started my flight i said home location as of aircraft and not remote .
If some one could please left me know what i am doing wrong and educate me.
Thank you.
2016-1-23
davidlwoodall
You may be within 20m of the home point? This post explains RTH very well:
http://forum.dji.com/forum.php?mod=viewthread&tid=38269&mobile=2
2016-1-23
dacofty
Flight distance : 1016214 ft
Hello if you are within 20 m of your home point it will land.  give it a try next time fly out 30 m anf then rth
2016-1-23
nabzo
South Africa
Yes I think that's the thing I'm close to my drone like 5m just trying to play it safe tomorrow I willl try more then 30m . should I make my home point the aircraft or remote position .
2016-1-23
davidlwoodall
nabzo@me.com Posted at 2016-1-23 08:21
Yes I think that's the thing I'm close to my drone like 5m just trying to play it safe tomorrow I wi ...
It will set its own home point (listen to verify it has, then double check in DJI GO app). If within 20m of that point, it will land where it is. Further away, it will ascend to the RTH height (set in GO app), return in a straight line, then descend to landing. The post I linked explains it all very well. VERY IMPORTANT to verify home point has been set, and your RTH height is high enough to avoid any obstructions in the straight line return to home.
2016-1-23
nabzo
thank you I have had a good read on you link you sent . thank you ,, I have noticed the "H" in green on App but I do not hear it verifying and setting home point I know from videos I have been watching that on the app the voice with say home point set automatically with out me selecting to capture home point been either aircraft or remote.
for argument sake which is the best option to choose to have home point ? Aircraft or remote ?
2016-1-24
Geebax
nabzo@me.com Posted at 2016-1-25 18:43
thank you I have had a good read on you link you sent . thank you ,, I have noticed the "H" in green ...
Always the departure point of the aircraft unless you move away from there with the RC. A classic case would be if you got in a car and drove away from where you started, taking the RC unit with you.
However, and this is important, your display device MUST have GPS capability to set the new home point, and they are not always that accurate. It is a dicey thing to do.
2016-1-25
WetDog
Flight distance : 1131886 ft
For simplicity's sake, Geebax is correct.  Set the AIRCRAFT Homepoint.
2016-1-25
nabzo
Switzerland
thank you .
2016-1-25
