afiend69
Flight distance : 626647 ft
App says "Weak image transmission signal"
Channel info says "strong interference... "
I upgraded from 1.3 to 1.6 and now my P3P is a door stop.
I can connect to the drone, once in a while I can fly it just by video display... not today though.
The video display is OK but I cannot communicate with the drone at all via the android app.
I can't see drone version or do simple stuff like change channel, it fails always.
I can downgrade the drone and upgrade at will, but doesn't help at all.
I can move the gimbal up and down.... even now when it won't spin the props
Problem may be in the RC but I cannot re-flash it or downgrade it....
the forum won't let me format or add photos.. ugh
info from most recent part of log file.
[00012740]========== remo-con disconnect. boot(15) ============
[00012799]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x011ca889].
[00012858]Packet upgrade start...
[00012928]Packet checking...
[00012987]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013042]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013105]Done.
[00013162]Version checking[1]...
[00013262][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013362][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013430][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013562][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013666][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013767][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013867][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013966][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014132][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014226][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014391][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014467][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014524][01 00][00] v1.26.4315 -> v1.26.4315
[00014586][01 01][00] v1.26.4315 -> v1.26.4315
[00014663][08 00][00] v0.13.0.7 -> v0.13.0.7
[00014753][09 00][00] v2.13.0.0 -> v2.13.0.0
[00014806]Packet upgrade cancelled at version checking.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft. |
