how to create a Timelapse while Sun goes down?
926 2 2016-1-24
m.friedl
Flight distance : 3 ft
Austria
i´m trying to find the right Setting for Timelapse when Sun goes down.
I did that today but in Auto Mode the Movie is even getting not darker and i knew this comes from ISO and Shutterspeed.
Should i set only ISO to 100 or is there more to do?
What Setting would you recomend to me to get a nice Timelap?
Thank you ALL
2016-1-24
rj74
Set Osmo to 'M' (manual mode).
If it is daytime set ISO to 100. (for lower light situations you would need to raise ISO, but always keep ISO as low as possible for better quality)
Set shutter to give correct exposure EV = 0
Set White Balance to a fixed setting e.g 'Sunshine'
Then go ahead and set time lapse settings and tap start. You can experiment with Interval and Duration to get effect you want.
2016-1-24
m.friedl
Austria
Thank you RJ,
It will be very tricky to find the "correct Shuttertime" when Sun goes down but i´ll give it a try that way
2016-1-25
