terrylewis
Flight distance : 3517287 ft
SVTRay,
First, double check that your RC antenna are parallel and oriented parallel to the legs of your P3. The antenna you're trying to link to are in the legs of the P3 and the flat side of the antenna should be parallel to the legs.
Next, turn on the RC and connect your mobile device. Launch the GO App.
Next, Turn on the P3 and watch for the RED link LED on the side of the VPS housing on the gimbal motor side of the aircraft. This LED will turn GREEN when link is established, but will stay RED if no link is negotiated.
Does the link LED on the side of the aircraft stay RED?
Back in the GO App, enter Camera View and tap the RC Control Setting icon up on top next to the Aircraft Status.
Down at the bottom, select Linking RC. Your left most RC Status LED should start blinking BLUE.
Does the RC Status LED start blinking BLUE and beep & the GO App display a 60 second timer?
Back on the aircraft, just to the right of the RED link LED, is a button inside a small hole. You'll need a paper clip, toothpick, or small screwdriver to depress the link button. Press and hold the link button depressed. The RED LED just next to the button should turn GREEN. You can now release the link button when the LED turns GREEN.
And if you look back at the RC, its status LED should also be GREEN.
Advise at which step you're observing something different..... |
