Thumb Controller Variable Pan and Tilt Speed?
876 2 2016-1-26
igraphyx
Flight distance : 78737 ft
Hello,
I'm new to using the Ronin and I've just completed setting it up along with a Thumb Controller. when pressing the pressure sensitive control buttons on the Thumb controller I see feedback on the display that matches how hard or soft I press it. I thought that would mean that I could Pan slowly with a soft touch, and then Pan faster by pressing harder. That doesn't seem to happen when I'm actually using it. The Pan and Tilt speeds are constant no matter what pressure i'm pressing the buttons with.
Am I missing a setting, or doing something wrong? What's the purpose of having the buttons pressure sensitive if not to control Pan/Tilt speed?
Please help. Thanks.
Reynaldo
2016-1-26
igraphyx
Update: I think I've discovered the problem. I've found that increasing the Maximum speed to a high value allows me to pan slow with a soft press, then pan to that maximum value with a full press. Interestingly, it seems that by doing this, the preset speeds I set for "slow" "normal" and "fast" are overridden by the maximum speed.
2016-1-26
DJI-Cathy
{:3_48:}
2016-1-26
