WIN DRIVER NOT WORKING
2323 5 2016-1-30
Gobokinetic
Hello Everyone, I have been away for a while and had to get a new nasty windows 8 laptop.
When I download the Phantom 2 WIN driver from the support page in either zip or exe format and run the new software after downloading it does not work
any help would be great
2016-1-30
Gobokinetic
The signature of DJI_WIN_Driver_Installer.exe Is corrupt or invalid ???
2016-1-30
Northofthe49th
check your security and administrative priveleges are set properly, turn off anti virus for the install etc.
Delete and download again and give that a try...
and download the .exe file and then run from your pc, do not do the "run" from their site...
2016-1-30
roy
When you do the above right click and run as administrator also.
2016-1-31
quanthonytrang
Flight distance : 419980 ft
Clear your cache or try different browser.
Executable - you need to allow otherwise it just gets blocked by windows.
http://dl.djicdn.com/downloads/d ... river_Installer.exe
Zip
http://dl.djicdn.com/downloads/d ... river_Installer.zip
2016-2-2
chowdah
I was getting the "This App has been blocked for your protection"  error when trying to install the drivers on Windows 10.   I tried disabling driver signature verification, shutting off virus protection, launching the installer as an admin, and all kinds of other stuff. The only way that worked was booting into safe mode and installing the driver. In safe mode Windows didn't see the drone or the RC when plugged into the usb port, but I installed anyhow, thinking the usb channel I was using was disabled in safe mode.  When I logged into the computer out of safe mode, the Vision Assistant 3.8 Software linked to the drone.  Using that software I calibrated the RC through the drone.  Couldn't get DJI RC Assistant version 1.2 to work with a direct connection to the RC unit with USB, but I can still charge the unit that way. I'm using an older software for an older drone, but the driver signature problem is the same for any other unsigned DJI drivers, so this may work for all of their older unsigned drivers.
2019-5-21
