Problem With Video Jello Shaking ??
1870 11 2016-1-30
hudiaratama
Indonesia
please help!
I get a jello or shaking result on my inspire 1
Prop not balance? Already change a new props
Change the dumpers? Already change all dumpers
Change the X3 camera? Already change to other X3 cameraI also try the X5 kit mount and the result still the same
https://www.youtube.com/watch?v=pXyaw7lqoCo
2016-1-30
daniel.frederik
Flight distance : 10656 ft
New Zealand
Hi, put your ND filter on your camera and the problem should disappear
2016-1-30
teamnest1
Flight distance : 18484 ft
Try ATTI mode next time
2016-1-30
RichJ53
Flight distance : 1837356 ft
Did you try the IMU Calibration and compass calibration?
This seems to be more than I would expect to see on the Inspire !. I do not have that much on my P3P camera
Rich
2016-1-30
DJI-Tim
What lens are you using? Please do the gimbal calibration, and lens calibration, so problem should disappear
2016-1-31
Machoman
Flight distance : 1036959 ft
Austria
DJI-Tim Posted at 2016-2-1 04:18
What lens are you using? Please do the gimbal calibration, and lens calibration, so problem should d ...
What is a lens calibration on the X3 did I overlook something?
2016-2-2
Machoman
Austria
Did you have this from the beginning or it suddenly appeared and has not been before?
2016-2-2
DJI-Tim
Machoman Posted at 2016-2-3 03:36
oh missed that, I tought he was flying with X5
2016-2-2
DJI-Tim
Make sure your gimbal lock ring is locked tightly
2016-2-2
Starship
I have really nothing to add to the other suggestions..... but, that is the worst jello, I have seen in a long time.
I do however suggest that you hover in front of you and watch the arms and see if they are shaking.
2016-2-4
DJI-Ken
Flight distance : 1515312 ft
Starship Posted at 2016-2-5 03:29
I have really nothing to add to the other suggestions..... but, that is the worst jello, I have seen ...
Exactly what I was going to say, it looks pretty severe. But didn't mention about aircraft shaking like I would think would be happening from the amount of vibration.
2016-2-4
DJI-Ken
Do you still have the vibration issue? If not, what cured it?
If so, has any of the suggestions helped at all. IMU calibrations, gimbal calibrations, and so on.
Can you post a short video showing the aircraft hovering so we can see if it is vibrating  or not.?
And was it like this from new, or did you have an accident and then it started?
2016-2-4
