retret66
I totally love my Inspire 1 and this very reason I had to return it, DJI did not want to replace it and they just want it returned for a full refund ( I totally gave them that, good support at least for me).. Does this means they know that this is an ongoing issue? I still however ordered the OSMO for this upcoming vacation together with external mic and extension stick.. I ordered it direct from DJI.. Hopefully there is only a small percentage of this and I will get a good one..In any case, I think the issue is that if you leave the bin file on the sd card, the camera will boot up and will check for a valid update on root of the SD card, it verify against your software and will skip update and then it will boot. The problem I experience is that, if you forget to remove the bin file, it might fail to verify the version and will go and reupdate your firmware.. |
