X5 stuck on aircraft!
617 1 2016-1-31
TravisSRT
Flight distance : 68555177 ft
I received my I1 Pro yesterday.  Installed the X5 onto the aircraft per the directions.  Flew 10-12 batteries today with no issues.  Went to remove the X5 to put it back in landing mode and it will not release from it's mount.  The lock/unlock ring doesn't seem to want to turn very easily and when you apply pressure it will not turn fully to the unlock line.  The camera and gimbal still work perfectly but I can't get it off to put back in the case.  Any suggestions?  I have checked and everything is lined up perfectly and it is installed per the owners manual directions.  Any help would be greatly appreciated!
2016-1-31
DJI-Adela
Hello!
Have you solved the problem? Was it caused because of the temperature condition?
2016-2-15
