DaGunn
Flight distance : 203117 ft
Here is an option for your consideration.
A soft storage bag for a 4-section flyrod would hold each prop in a seperate pocket. You would need to cut the bag down to a shorter length though.
To make it military grade protection, get some PVC drain pipe of sufficient diameter to hold the rolled up bag of propellers. The length of the pipe should be longer than the props themselves, to accommodate the foam padding at each end of the pipe. Add two PVC end caps, gluing one cap into place and using the other as the lid. |
