Brand New Inspire 1 Pro Dead tb47
1689 11 2016-2-6
karlrigby
Flight distance : 546014 ft
Brand new never used inspire 1 pro Battery won't switch off (red light stays on) and the first green light is also flashing on and off!!
No firmware update have been done on the battery! can't switch it off (single press then long press)
Tried putting it in the inspire but still same thing. tried charging it over 12 hours still same thing.
Any Ideas before I take it back to the shop on Monday?
2016-2-6
R&L Aerial
Flight distance : 298100 ft
Take it back, it's busted.
2016-2-6
RichJ53
Flight distance : 1837356 ft
Can you take a video and post it showing the problem? If you hold the button down for 30 seconds will it shut off?
Did you say you can start up the Inspire 1 with the battery and remote? or is the battery flashing all of the time?
sounds like a defective battery or other problem.
Rich
2016-2-6
goviral
I currently have the same exact problem, and I mean exact.  Red Light, and one green light are flashing, and will not turn off.  I have put it in the inspire, and it does not power up the Inspire.  I guess I will let it blink until it completely goes dead.  Do I send it back?  Do I discard it?  Or do I try to remove the cover and re-set by disconnecting the balance wire?  Anyone with input please reply.  Thanks.
2016-2-6
RichJ53
goviral Posted at 2016-2-6 19:52
I currently have the same exact problem, and I mean exact.  Red Light, and one green light are flash ...
Sorry man, this is a bummer
its under warranty so if you take the top off, your warranty will be void...
Just contact support and send it back to DJI
Rich
2016-2-6
Alastair
Flight distance : 96631 ft
RichJ53 Posted at 2016-2-6 23:55
its under warranty so if you take the top off, your warranty will be  ...
Yep, Rich is right, don't open it.
2016-2-6
karlrigby
RichJ53 Posted at 2016-2-7 15:25
Under Warranty for sure just though there might have been a quick fix (save driving to the shop and back) hour and thirty mins wasted
2016-2-6
RichJ53
karlrigby Posted at 2016-2-6 21:00
Under Warranty for sure just though there might have been a quick fix (save driving to the shop an ...
I have seen some success posted in the forum, popping off the top and unplugging for the reset.. but if it doesn't work your out 150 bucks
Rich
2016-2-6
Seven Oaks
Flight distance : 191952 ft
Mine was doing the same thing on the charger tonight, however I left it there and it started charging correctly.  All is good now!
2016-2-7
karlrigby
Seven Oaks Posted at 2016-2-7 21:24
Mine was doing the same thing on the charger tonight, however I left it there and it started chargin ...
Had the battery in the inspire to try flatten/ discharge for a while, the first green light kept flashing green and slowly got dimmer over about 6 hours. then put it on the charger before I went out. Just got back home and all lights are now off and it won't initialise (no lights at all)
2016-2-7
goviral
RichJ53 Posted at 2016-2-6 22:55
Unfortunately, I have had this battery about a year, so I do not believe it is covered by warranty.  It has less than 200 charge cycles, but it's over 6-months.  It's the TB47 that came with the Inspire I, which I purchased in January of last year.  May just have to eat it, and buy a new one, but I do have other TB48s and they haven't had any issues to this point.
2016-2-7
RichJ53
goviral Posted at 2016-2-7 08:56
Unfortunately, I have had this battery about a year, so I do not believe it is covered by warranty ...
in this case you do not have anything to lose. the battery warranty is only 90 days, I ran into this with one of mine and it was no longer covered
Go for it... maybe it will start up again
Rich
2016-2-7
