filmscum
Jamaica
Yes Sir, I have iPad mini and hood (it will not fit the iPad Air without a mod), 5 batts total (2 proper battery slots, 2 are in the 2nd controller slot as I fly solo and 1 in the bird) there are areas in the lid for props (4 total so theoretically you could carry 16 props). It comes with a gimbal lock so you can keep the X3 attached and it's pretty solid. Also a spot for the original camera box, and a spare spot that I put my battery heater and controller lanyard in. When zipped closed I can quite literally shake it an nothing moves.
Yes Paul it is a bit fatter than the original but not as wide. This is because it is a landing mode case and the camera and gimbal are still attached. Trust me having used the straps this is by far more comfortable, but if you truly need it to accompany 8 batteries and be the same height as the original case it probably won't work. |
