Riley-NZL
New Zealand
Yes, you have to turn them until you see the reflections go away/sky darken. Unfortunately they won't stay in that position unless your lucky enough to get one that just happens to be in the perfect position at full tightness. If you really want to get it to work, fully tighten it, then loosen it off until it's in the right position, then use tape/rubber band etc to hold it in position and make sure it doesn't vibrate off.
The only way to know it's in the right position is to look at the live view image and see the effect on the image (kinda like manually focusing).
