New firmware. When?
1044 6 2016-2-11
imagines.and.wo
Croatia
Horisont issue... Looks like after first IMU calibration it comes and go by random. Also if you pan left/right..
I just checked footage and some clips are perfect, then some are tilted a lot. I can clearly see, hope to have time to upload results to youtube..
Do we have any info about new firmware?
2016-2-11
terrylewis
Flight distance : 3517287 ft
Did you perform a GIMBAL Auto Calibration following your IMU calibration? (Under Gimbal Param Settings) advance to  5:40 in this video:
2016-2-11
imagines.and.wo
Croatia
Sure. Did it three times during few days. It's good most of time. But randomly gets tilted. Also camera down/horizontal manages to correct it.
Carefully watching footage it can be seen that during pan it gets titled. Also found same problem of other users on youtube vids. Firmware software clearly can be better.
2016-2-11
imagines.and.wo
Croatia
UP UP UP
2016-2-12
terrylewis
imagines.and.wo Posted at 2016-2-12 02:13
Sure. Did it three times during few days. It's good most of time. But randomly gets tilted. Also cam ...
i&w,
   Take a look in the your GO App and see what Gimbal Mode you're using. It's under Gimbal Param Setting. The P3 has two modes: FOLLOW (normal) and FPV (first person view -> banking). This video shows the difference. Is this what your are seeing?
2016-2-12
j30trouble
Flight distance : 441010 ft
I was having some horizontal issues with my drone video. I will have to check to see what mode I was in. Thank you for the video. It was a great explanation of those two modes.
2016-2-12
imagines.and.wo
Croatia
thanks guys but i understand FVP & Follow modes. That's not point.
I found that after first stock IMU calibration (cold or not with perfect level) most devices will have tilted horizon after long pan. I'll try to make vid.
It's not too bad, it's not un acceptable but there is some tilt. You can clearly see it.
At least my device with 1.6FW
2016-2-13
