dwayne.henry
The tilt axis on my DJI Ronin-M is not working properly. I just received it in the mail on Monday mind you from BH.
I'm using a BMCC 2.5k stripped down with a Canon 16-35 L series II lens.
I've got it perfectly balanced when the Ronin battery is off with the camera pointing straight ahead. It was working perfectly with the Power reading just about 0 for each axis and the angle as well. However since that first day I updated my firmware, did the calibrations and since then the tilt axis has been facing down after the motor starts up.
On the DJI Assistant app the angle for tilt reads 17%! the power on the tilt is between 2 and 3. Roll and Horizontal are still operating properly at 0 all around.
Any ideas on how I can get my tilt to start up at the proper angle?
Note: I've already tried Calibration and it's not that. I don't want to adjust the trim. I would like a precise fix.
Thank you!
