Sony FS700 & Ronin Balancing problem
1380 2 2016-2-14
andy
Hi, my new Ronin arrived last week  that I'm trying to use with my Sony FS700.
I also bought the Cinemilled extension arms.
I have tried to balance the Ronin for a few days - I have watched many videos and tutorials and seem to be doing things right, but it fails to stay balanced, especially If I try and balance another part of the Ronin. It's like taking 1 step forward, 2 steps back!
I'm using the Kit lens (18-200mm) but I also have some Canon 28mm & 50mm lenses that I haven't tried yet.
Can anyone offer any tips or advice in using this specific camera. I've seen some great videos online using this combination, so it must be possible unless I have a faulty unit.
Do I need the Extension arms?? Could that be part of the problem??
Thanks in advance for your help.
Andrew
2016-2-14
valealvarez.s96
Argentina
it's hard if you are not used to balance gimbals, i felt the same as you (ronin-m) if you change one axis, the other 2 always gets affected by little or by a lot, you have to check back all times, once you understand how it behaves then you will get shorter setup times
2016-2-14
valealvarez.s96
Argentina
try smaller lenses too, maybe that will help you. for me the tilt axis is the hardest to get it perfect
2016-2-14
