Geebax
"For example: one fact that seems to have been overlooked in this instance is that before flying behind the second building the aircraft flies behind an identically shaped first building and maintains "good" signal the entire way. Just because it did on the first doesn't mean it will on the second but it is still evidence to be considered, it does weaken the validity of the hypothesis that RTH initiated a building collision."
This is a good point, however the vagaries of radio propagation also come into the equation. There could have been reflection from other buildings, or that section of the flight was faster. It is still highly probable that the aircraft crashed on RTH, otherwise if it flew in any other direction, it should have regained signal again.
One of the problems here is that while some owners do not read the manual, and others religiously do, there is really no material published that imparts knowledge of the problems in flying in these circumstances. Looking at the issues raised on this forum shows that there are many nuances of the flying art that are not published, and this is one of them.
No one tells you that if you fly behind a building, hill or whatever that you may lose signal, and if that happens, a whole new set of circumstances comes into play. You are quite correct, we should not be critical of the OP in this regard, as it is a reasonably understandable mistake to fall into.
The one rule that applies here very strongly is the one about not letting your aircraft fly out of visual range. But the very technology in these aircraft encourages you to do so, because the camera lets you see quite clearly where you are flying. Or so it would seem.
Radio communication is a very difficult technology, but one thing can be relied upon, if you can't see your aircraft, then the radio probably can't either. I think this is a subject that DJI could address as one of their tutorials.
