clay
Santa brought me a shiny new P2V+, and so far I love it!
Have been (cautiously!) increasing the max height setting in the Assistant software program, have now flown up to 600 ft high and about 700 ft out.
I am getting occasional losses in both the FPV camera connection (that's the Wi-Fi module, right?) and the TX as well. So far no real PROBLEMS... failsafe has kicked in a couple times and returned all the way home perfectly, and a couple of times I have manipulated the S1 switches to regain control (I'm now in NAZA mode) - all good safe landings so far.
I've seen some threads discussing better antennas, but so far none that are easy enough to fully understand for a rookie like me!
Specifically...
1) To increase flight range, will just screwing a better antenna onto the transmitter (without changing anything inside the bird) get me more flight range, or do I have to change something inside the bird as well?
2) To increase FPV camera range, do new antennas need to be installed inside the Wi-Fi module, or is it best to change out the module completely to a better one? And would I also need to modify anything inside the the bird itself to increase FPV camera range, or just on the Wi-Fi module on the transmitter?
Any and all help/thoughts/links are greatly appreciated!
bugman
