Advanced. Air time about 10 mins. Will not boot up
921 8 2016-2-19
Gally
Bought my advanced in January, last month.
I updated batteries, aircraft and RC to latest firmware.
Went on its maiden voyage and went well, no problems. (This is my first quadcopter), so I only spent 5mins using it, learning the controls.
Yesterday would have been its second flight. When I turned it on, there was a continous beeping soung on and off, the RC could not locate it.
So I turned it off, formatted the sd card, and put 1.6 firmware back on the sd card.
Turned on the battery, again same beeping noise. Indicator started to flash red & green. LEDs on aircraft (two red and two flashing yellow).
I thought all was fine, updating, but then after about 2 mins the noise changed from beeping to continous, and the indicator light stopped flashing red & gree to a solid red. The LED light on aircraft remained the same (2 solid reds and 2 flashing yellow)
I tried multiple attempts to load the firmware again, even left it on until the battery practically drained (well over an hour) and still no change.
I sent and email to support, which I think ended up in China, so I sent it again to EU support.
I've heard nothing.
I spoke to technical support an hour ago, and we went through a fault finding exercise but still no joy, eventually their CS rep said send an email to support again.
How long does it take for support to get in contact?
I'd say I'll have to send back the P3 and get a replacement.
Cheers
Joe
2016-2-19
[RCG]Balthazar
Flight distance : 475371 ft
Norway
What does the text file from your sd card say? Paste it here
2016-2-19
Gally
[RCG]Balthazar Posted at 2016-2-19 15:33
[00013661]========== remo-con disconnect. boot(15) ============
[00013799]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00013836]Packet upgrade start...
[00013876]Packet checking...
[00013921]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013987]Done.
[00014024]Version checking[1]...
[00014096][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014156][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00014198][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014316][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014415][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014515][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014616][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014714][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014750][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014825][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014975][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015021][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015056][01 00][00] v1.21.3647 -> v1.22.4095 need upgrade
[00015089][01 01][00] v1.21.3647 -> v1.22.4095 need upgrade
[00015141][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00015181]Done.
[00017216]Waiting for user confirm...
[00027250]Timeout, start upgrade automatically.
[00027319]Firmware upgrading[1]...
[00043724][01 00] Firmware upgrade start...
[00013232][01 00] Firmware upgrade finished successfully.
[00013405]Done.
[00013852]Packet [C:\P3S_FW_V01.06.0040.bin] resumed, card sn [0x1e707c20].
[00014241]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014718]Version checking[2]...
[00015137][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015677][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00016066][04 00][00] v1.41.0.0 -> v1.41.0.0
[00016456][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00016959][12 00][00] v1.10.0.0 -> v1.10.0.0
[00017219][12 01][00] v1.10.0.0 -> v1.10.0.0
[00017319][12 02][00] v1.10.0.0 -> v1.10.0.0
[00017409][12 03][00] v1.10.0.0 -> v1.10.0.0
[00017448][15 00][00] v1.1.2.0 -> v1.1.2.0
[00017522][17 00][00] v1.1.1.7 -> v1.1.1.7
[00017638][17 01][00] v1.0.2.7 -> v1.0.2.7
[00017797][19 00][00] v1.0.8.96 -> v1.0.8.96
[00017833][01 00][05] v1.22.4095 -> v1.22.4095
[00017878][01 01][00] v1.21.3647 -> v1.22.4095 need upgrade
[00017933][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00017969]Done.
[00018010]Firmware upgrading[2]...
[00018169][01 01] Firmware upgrade start...
[00048486][01 01] Firmware upgrade finished successfully.
[00048534][11 00] Firmware upgrade start...
[00098330][11 00] Firmware upgrade finished successfully.
[00098602][03 06] Firmware upgrade start...
[00433535][03 06] Firmware upgrade finished successfully.
[00433599][09 00] Firmware upgrade start...
[00487095][09 00] Firmware upgrade finished successfully.
[00487137]Done.
[00487174]Version checking[3]...
[00487248][03 05][00] v34.2.0.9 -> v34.2.0.9
[00487327][03 06][05] v2.4.10.7 -> v2.4.10.7
[00487370][04 00][00] v1.41.0.0 -> v1.41.0.0
[00487489][11 00][05] v1.7.15.1 -> v1.7.15.1
[00487576][12 00][00] v1.10.0.0 -> v1.10.0.0
[00487668][12 01][00] v1.10.0.0 -> v1.10.0.0
[00487768][12 02][00] v1.10.0.0 -> v1.10.0.0
[00487868][12 03][00] v1.10.0.0 -> v1.10.0.0
[00487906][15 00][00] v1.1.2.0 -> v1.1.2.0
[00488002][17 00][00] v1.1.1.7 -> v1.1.1.7
[00488137][17 01][00] v1.0.2.7 -> v1.0.2.7
[00488192][19 00][00] v1.0.8.96 -> v1.0.8.96
[00488232][01 00][05] v1.22.4095 -> v1.22.4095
[00488270][01 01][05] v1.22.4095 -> v1.22.4095
[00488332][09 00][05] v2.13.0.0 -> v2.13.0.0
[00488368]Packet upgrade finish successfully.
[00013304]========== 2016.01.30 16:16:42. boot(15) ============
[00013338]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00013372]Packet upgrade start...
[00013408]Packet checking...
[00013444]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013477]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013511]Done.
[00013544]Version checking[1]...
[00013617][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013676][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013715][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013936][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014016][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014085][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014167][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014239][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014276][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014345][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014459][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014505][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014541][01 00][00] v1.22.4095 -> v1.22.4095
[00014576][01 01][00] v1.22.4095 -> v1.22.4095
[00014625][09 00][00] v2.13.0.0 -> v2.13.0.0
[00014661]Packet upgrade cancelled at version checking.
[00013770]========== 2016.02.17 16:40:41. boot(15) ============
[00013806]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00013845]Packet upgrade start...
[00013898]Packet checking...
[00013940]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013979]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00014024]Done.
[00014064]Version checking[1]...
[00014141][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014221][03 06][00] v2.4.10.7 -> v2.4.10.7
[00014266][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014381][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014501][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014606][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014719][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014810][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014858][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014950][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015085][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015141][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015181][01 00][00] v1.22.4095 -> v1.22.4095
[00015222][01 01][00] v1.22.4095 -> v1.22.4095
[00015276][09 00][00] v2.13.0.0 -> v2.13.0.0
[00015320]Done.
[00017360]Waiting for user confirm...
[00027404]Timeout, start upgrade automatically.
[00027490]Firmware upgrading[1]...
[00027543][11 00] Firmware upgrade start...
[00074936][11 00] Firmware upgrade finished successfully.
[00074982]Done.
[00075023]Version checking[2]...
[00075085][03 05][00] v34.2.0.9 -> v34.2.0.9
[00075284][03 06][00] v2.4.10.7 -> v2.4.10.7
[00075341][04 00][00] v1.41.0.0 -> v1.41.0.0
[00075446][11 00][05] v1.7.15.1 -> v1.7.15.1
[00075536][12 00][00] v1.10.0.0 -> v1.10.0.0
[00075621][12 01][00] v1.10.0.0 -> v1.10.0.0
[00075695][12 02][00] v1.10.0.0 -> v1.10.0.0
[00075794][12 03][00] v1.10.0.0 -> v1.10.0.0
[00075839][15 00][00] v1.1.2.0 -> v1.1.2.0
[00075919][17 00][00] v1.1.1.7 -> v1.1.1.7
[00076069][17 01][00] v1.0.2.7 -> v1.0.2.7
[00076129][19 00][00] v1.0.8.96 -> v1.0.8.96
[00076167][01 00][00] v1.22.4095 -> v1.22.4095
[00076206][01 01][00] v1.22.4095 -> v1.22.4095
[00076280][09 00][00] v2.13.0.0 -> v2.13.0.0
[00076321]Packet upgrade finish successfully.
[00013582]========== 2016.02.17 17:09:04. boot(15) ============
[00013623]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00013664]Packet upgrade start...
[00013712]Packet checking...
[00013755]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013796]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013837]Done.
[00013883]Version checking[1]...
[00013965][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014046][03 06][00] v2.4.10.7 -> v2.4.10.7
[00014093][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014225][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014345][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014445][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014545][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014645][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014692][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014789][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014933][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014998][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015040][01 00][00] v1.22.4095 -> v1.22.4095
[00015082][01 01][00] v1.22.4095 -> v1.22.4095
[00015138][09 00][00] v2.13.0.0 -> v2.13.0.0
[00015179]Packet upgrade cancelled at version checking.
[00013830]========== 2016.02.17 17:32:22. boot(15) ============
[00013873]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00014036]Packet upgrade start...
[00014083]Packet checking...
[00014127]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014166]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00014214]Done.
[00014256]Version checking[1]...
[00014339][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014415][03 06][00] v2.4.10.7 -> v2.4.10.7
[00014477][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014592][11 00][00] v1.7.15.1 -> v1.7.15.1
[00014694][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014793][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014903][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014979][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015028][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015103][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015223][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015283][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015334][01 00][00] v1.22.4095 -> v1.22.4095
[00015376][01 01][00] v1.22.4095 -> v1.22.4095
[00015444][09 00][00] v2.13.0.0 -> v2.13.0.0
[00015494]Packet upgrade cancelled at version checking.
[00023796]========== 2016.02.17 17:34:06. boot(15) ============
[00023839]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00023881]Packet upgrade start...
[00023927]Packet checking...
[00023976]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024018]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024061]Done.
[00024109]Version checking[1]...
[00024193][03 05][00] v34.2.0.9 -> v34.2.0.9
[00024294][03 06][00] v2.4.10.7 -> v2.4.10.7
[00024342][04 00][00] v1.41.0.0 -> v1.41.0.0
[00024474][11 00][00] v1.7.15.1 -> v1.7.15.1
[00024568][12 00][00] v1.10.0.0 -> v1.10.0.0
[00024670][12 01][00] v1.10.0.0 -> v1.10.0.0
[00024769][12 02][00] v1.10.0.0 -> v1.10.0.0
[00024870][12 03][00] v1.10.0.0 -> v1.10.0.0
[00024917][15 00][00] v1.1.2.0 -> v1.1.2.0
[00025018][17 00][00] v1.1.1.7 -> v1.1.1.7
[00025167][17 01][00] v1.0.2.7 -> v1.0.2.7
[00025228][19 00][00] v1.0.8.96 -> v1.0.8.96
[00025269][01 00][00] v1.22.4095 -> v1.22.4095
[00025310][01 01][00] v1.22.4095 -> v1.22.4095
[00025368][09 00][00] v2.13.0.0 -> v2.13.0.0
[00025513]Packet upgrade cancelled at version checking.
[00022996]========== remo-con disconnect. boot(15) ============
[00023039]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00023090]Packet upgrade start...
[00023137]Packet checking...
[00023182]Packet vlink 01.06.0040 <-> 01.05.0030.
[00023230]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00023273]Done.
[00023315]Version checking[1]...
[00035859][03 05][00] device not detected.
[00048402][03 06][00] device not detected.
[00048458][04 00][00] v1.41.0.0 -> v1.41.0.0
[00061006][11 00][00] device not detected.
[00073555][12 00][00] device not detected.
[00086098][12 01][00] device not detected.
[00098641][12 02][00] device not detected.
[00111184][12 03][00] device not detected.
[00133732][15 00][00] device not detected.
[00146281][17 00][00] device not detected.
[00158824][17 01][00] device not detected.
[00171366][19 00][00] device not detected.
[00171417][01 00][00] v1.22.4095 -> v1.22.4095
[00171461][01 01][00] v1.22.4095 -> v1.22.4095
[00184004][09 00][00] device not detected.
[00184052]Packet upgrade failed at version checking.
[00021986]========== remo-con disconnect. boot(15) ============
[00022026]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00022066]Packet upgrade start...
[00022113]Packet checking...
[00022158]Packet vlink 01.06.0040 <-> 01.05.0030.
[00022201]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00022243]Done.
[00022291]Version checking[1]...
[00034835][03 05][00] device not detected.
[00047377][03 06][00] device not detected.
[00047436][04 00][00] v1.41.0.0 -> v1.41.0.0
[00059979][11 00][00] device not detected.
[00072534][12 00][00] device not detected.
[00085077][12 01][00] device not detected.
[00097620][12 02][00] device not detected.
[00110163][12 03][00] device not detected.
[00132703][15 00][00] device not detected.
[00145246][17 00][00] device not detected.
[00157914][17 01][00] device not detected.
[00170465][19 00][00] device not detected.
[00170506][01 00][00] v1.22.4095 -> v1.22.4095
[00170552][01 01][00] v1.22.4095 -> v1.22.4095
[00183101][09 00][00] device not detected.
[00183145]Packet upgrade failed at version checking.
[00013770]========== remo-con disconnect. boot(15) ============
[00013810]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00013862]Packet upgrade start...
[00013908]Packet checking...
[00013951]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013999]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00014042]Done.
[00014085]Version checking[1]...
[00026628][03 05][00] device not detected.
[00039169][03 06][00] device not detected.
[00039223][04 00][00] v1.41.0.0 -> v1.41.0.0
[00051779][11 00][00] device not detected.
[00064322][12 00][00] device not detected.
[00076865][12 01][00] device not detected.
[00089408][12 02][00] device not detected.
[00101949][12 03][00] device not detected.
[00124494][15 00][00] device not detected.
[00137042][17 00][00] device not detected.
[00149585][17 01][00] device not detected.
[00162128][19 00][00] device not detected.
[00162175][01 00][00] v1.22.4095 -> v1.22.4095
[00162219][01 01][00] v1.22.4095 -> v1.22.4095
[00174762][09 00][00] device not detected.
[00174810]Packet upgrade failed at version checking.
[00026018]========== remo-con disconnect. boot(15) ============
[00026061]Packet [C:\P3S_FW_V01.03.0020.bin] detected, card sn [0x1e707c20].
[00026100]Packet upgrade start...
[00026148]Packet checking...
[00026209]Packet vlink 01.03.0020 <-> 01.01.0009.
[00026252]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 6).
[00026299]Packet upgrade failed at packet checking.
[00013755]========== remo-con disconnect. boot(15) ============
[00013797]Packet [C:\P3S_FW_V01.05.0030.bin] detected, card sn [0x1e707c20].
[00013850]Packet upgrade start...
[00013895]Packet checking...
[00014044]Packet vlink 01.05.0030 <-> 01.04.0010.
[00014086]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 1).
[00014139]Done.
[00014183]Version checking[1]...
[00026725][03 05][00] device not detected.
[00039274][03 06][00] device not detected.
[00039344][04 00][00] v1.41.0.0 -> v1.41.0.0
[00051885][11 00][00] device not detected.
[00064437][12 00][00] device not detected.
[00076981][12 01][00] device not detected.
[00089534][12 02][00] device not detected.
[00102078][12 03][00] device not detected.
[00124623][15 00][00] device not detected.
[00137165][17 00][00] device not detected.
[00149714][17 01][00] device not detected.
[00162258][19 00][00] device not detected.
[00162307][01 00][00] v1.22.4095 -> v1.22.4095
[00162352][01 01][00] v1.22.4095 -> v1.22.4095
[00174897][09 00][00] device not detected.
[00174947]Packet upgrade failed at version checking.
[00014256]========== remo-con disconnect. boot(15) ============
[00014300]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00014349]Packet upgrade start...
[00014392]Packet checking...
[00014439]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014483]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00014536]Done.
[00014579]Version checking[1]...
[00027124][03 05][00] device not detected.
[00039679][03 06][00] device not detected.
[00039736][04 00][00] v1.41.0.0 -> v1.41.0.0
[00052285][11 00][00] device not detected.
[00064830][12 00][00] device not detected.
[00077370][12 01][00] device not detected.
[00089923][12 02][00] device not detected.
[00102467][12 03][00] device not detected.
[00125015][15 00][00] device not detected.
[00137564][17 00][00] device not detected.
[00150108][17 01][00] device not detected.
[00162650][19 00][00] device not detected.
[00162702][01 00][00] v1.22.4095 -> v1.22.4095
[00162747][01 01][00] v1.22.4095 -> v1.22.4095
[00175290][09 00][00] device not detected.
[00175342]Packet upgrade failed at version checking.
[00023909]========== remo-con disconnect. boot(15) ============
[00023957]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00024009]Packet upgrade start...
[00024063]Packet checking...
[00024112]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024165]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024215]Done.
[00024263]Version checking[1]...
[00036819][03 05][00] device not detected.
[00049366][03 06][00] device not detected.
[00049441][04 00][00] v1.41.0.0 -> v1.41.0.0
[00061990][11 00][00] device not detected.
[00074538][12 00][00] device not detected.
[00087085][12 01][00] device not detected.
[00099638][12 02][00] device not detected.
[00112190][12 03][00] device not detected.
[00134738][15 00][00] device not detected.
[00147284][17 00][00] device not detected.
[00159839][17 01][00] device not detected.
[00172385][19 00][00] device not detected.
[00172431][01 00][00] v1.22.4095 -> v1.22.4095
[00172483][01 01][00] v1.22.4095 -> v1.22.4095
[00185038][09 00][00] device not detected.
[00185085]Packet upgrade failed at version checking.
[00023894]========== remo-con disconnect. boot(15) ============
[00023942]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00023992]Packet upgrade start...
[00024042]Packet checking...
[00024094]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024146]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024191]Done.
[00024237]Version checking[1]...
[00036784][03 05][00] device not detected.
[00049331][03 06][00] device not detected.
[00049391][04 00][00] v1.41.0.0 -> v1.41.0.0
[00061943][11 00][00] device not detected.
[00074489][12 00][00] device not detected.
[00087040][12 01][00] device not detected.
[00099586][12 02][00] device not detected.
[00112139][12 03][00] device not detected.
[00134685][15 00][00] device not detected.
[00147240][17 00][00] device not detected.
[00159786][17 01][00] device not detected.
[00172339][19 00][00] device not detected.
[00172505][01 00][00] v1.22.4095 -> v1.22.4095
[00172553][01 01][00] v1.22.4095 -> v1.22.4095
[00185100][09 00][00] device not detected.
[00185147]Packet upgrade failed at version checking.
[00022007]========== remo-con disconnect. boot(0) ============
[00022059]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00022111]Packet upgrade start...
[00022161]Packet checking...
[00022215]Packet vlink 01.06.0040 <-> 01.05.0030.
[00022267]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00022315]Done.
[00022363]Version checking[1]...
[00034917][03 05][00] device not detected.
[00023899]========== remo-con disconnect. boot(0) ============
[00023947]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00023999]Packet upgrade start...
[00024052]Packet checking...
[00024102]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024151]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024199]Done.
[00024251]Version checking[1]...
[00036804][03 05][00] device not detected.
[00023919]========== remo-con disconnect. boot(0) ============
[00023975]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x1e707c20].
[00024024]Packet upgrade start...
[00024074]Packet checking...
[00024134]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024183]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024228]Done.
[00024276]Version checking[1]...
[00036834][03 05][00] device not detected.
[00049382][03 06][00] device not detected.
[00049455][04 00][00] v1.41.0.0 -> v1.41.0.0
[00062003][11 00][00] device not detected.
[00074556][12 00][00] device not detected.
[00087104][12 01][00] device not detected.
[00099654][12 02][00] device not detected.
[00112203][12 03][00] device not detected.
[00134753][15 00][00] device not detected.
[00147301][17 00][00] device not detected.
[00159854][17 01][00] device not detected.
[00172402][19 00][00] device not detected.
[00172456][01 00][00] v1.22.4095 -> v1.22.4095
[00172504][01 01][00] v1.22.4095 -> v1.22.4095
[00185158][09 00][00] device not detected.
[00185211]Packet upgrade failed at version checking.
2016-2-19
Gally
Hi Ken.
Started aircraft and controller
App Version - 2.60
RC Version 1.5.70
Flight Controller Serial Number - N/A
Solid red light on RC.
10mins - turned off aircraft and controller.
Formatted sd card (original sd card sent by DJI), downloaded the latest advanced firmware P3S_FW_V01.06.0040 bin zip file to desktop, and extracted bin file to formatted sd card.
Started up aircraft (left controller off)
10 sec mark when camera stops moving, DD pause DD pause DD pause
40 sec mark tone change to DDDD pause DDDD pause DDDD. (indicator on gimble red to green)
3:10 min mark tone changes to a continuous tone DDDDDDDDDDD no pause. (indicator on gimble steady red)
Log File (last portion)...
00024304]========== remo-con disconnect. boot(15) ============
[00024363]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x285231a3].
[00024418]Packet upgrade start...
[00024479]Packet checking...
[00024538]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024592]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024653]Done.
[00024706]Version checking[1]...
[00037260][03 05][00] device not detected.
[00049816][03 06][00] device not detected.
[00049882][04 00][00] v1.41.0.0 -> v1.41.0.0
[00062444][11 00][00] device not detected.
[00075115][12 00][00] device not detected.
[00087678][12 01][00] device not detected.
[00100238][12 02][00] device not detected.
[00112798][12 03][00] device not detected.
[00135358][15 00][00] device not detected.
[00147918][17 00][00] device not detected.
[00160483][17 01][00] device not detected.
[00173040][19 00][00] device not detected.
[00173104][01 00][00] v1.22.4095 -> v1.22.4095
[00173159][01 01][00] v1.22.4095 -> v1.22.4095
[00185718][09 00][00] device not detected.
[00185787]Packet upgrade failed at version checking.
Hope you can help Ken.
2016-2-19
DJI-Terry
China
Gally Posted at 2016-2-20 07:03
Hi Ken.
Joe, too many modules are not detected. Would you pls double check the  gimbal wiring?
2016-2-19
DJI-Ken
Flight distance : 1515312 ft
Hi Ken.
I thought I responded to you, but don't see my post. Maybe you posted in another thread as well.
But yes, along with what I said Terry's got a great idea and possibly the wiring.
2016-2-19
Gally
DJI-Terry Posted at 2016-2-20 01:16
Will do Terry.
It didn't fall or nothing, but I will check.
Will i remove the gimbal and unplug and replug the connectors, like seen here in this
Thanks
2016-2-20
Gally
DJI-Ken Posted at 2016-2-20 01:30
B ...
Hi Ken
Yes I did what you asked in a previous thread, and in my post above I posted the log file.
It made no difference, still getting all those device not detected.
Thanks for your help
2016-2-20
Gally
Ok, did what you asked.
Check both cables, and they were fine. I removed them and re-inserted them.
Same process again, formatted sd card, put bin file onto it, and started aircraft.
Log file...
00024423]========== remo-con disconnect. boot(15) ============
[00024478]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x285231a3].
[00024540]Packet upgrade start...
[00024600]Packet checking...
[00024661]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024722]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00024778]Done.
[00024834]Version checking[1]...
[00037399][03 05][00] device not detected.
[00049960][03 06][00] device not detected.
[00050058][04 00][00] v1.41.0.0 -> v1.41.0.0
[00062620][11 00][00] device not detected.
[00075180][12 00][00] device not detected.
[00087740][12 01][00] device not detected.
[00100299][12 02][00] device not detected.
[00112860][12 03][00] device not detected.
[00135420][15 00][00] device not detected.
[00147979][17 00][00] device not detected.
[00160539][17 01][00] device not detected.
[00173100][19 00][00] device not detected.
[00173156][01 00][00] v1.22.4095 -> v1.22.4095
[00173225][01 01][00] v1.22.4095 -> v1.22.4095
[00185780][09 00][00] device not detected.
[00185842]Packet upgrade failed at version checking.
Same errors again .
2016-2-20
