Donnie
Flight distance : 3636782 ft
Ok , do a normal flight, walk away from your take off point and be at least 65 plus feet away. ( From Take off Point ) Fly normally and have some fun ....... as your battery gets below say 20 % let it hover about 4 feet in the air ( at least 65 plus feet away from take off point) Let the aircraft enter low battery Smart Go Home
Now when it initiates this (RTH low battery ) function see if you notice the aircraft asending quickly AS it is giving the announcement that Return to Home point is initiating. THIS IS THE PROBLEM , it is not giving the pilot enough time to react and shut off the option. ( If indeed that is what is wanted) There will be a pop u on the main screen but by this time the aircraft is already ascending. ( I also think the sticks wont function as well but am not posotive ) THIS IS WHERE I WOULD LIKE TO SEE THE DELAY.
Thanks for trying to duplicate, I think you will see that there is no delay when Smart Go Home initiates .
"If your outside the 20m and you get the low battery warning, you still have 10 seconds until it goes into RTH mode and you can cancel it at any time."
This is the line ( above) I do not agree with, It does not give you 10 seconds, it starts ascending AS it gives the warning. I mean you can cancel it, it is just not giving enough time before initializing.
Let me know- cheers donnie
