Should battery be at 100% every flight?
DaveB68
Hi all
Took my new P3A out for a quick test flight yesterday. Only about 5 minutes as it got quite breezy I called it a day. Question is after about 5 mins of use should I charge the battery fully again before flying? Is it best to have a full battery every flight or is it ok to start flying on around 75%?
Cheers
2016-2-20
todor
Flight distance : 2192221 ft
Always fully charge your battery or batteries before flight! Always
2016-2-20
RedHotPoker
Flight distance : 165105 ft
You may see a fully charged battery show just 97%. This is completely normal.
Once you deep cycle your battery packs, after 20 complete charges, they should come back to a full 100% charge.
That's what I have noticed with my four intelligent flight batteries. YMMV.
RedHotPoker
2016-2-20
Stanley Fredrik
Flight distance : 148556 ft
Finland
Yes! What todor say always flight with full charge battery. Specially in cold weather the battery drain faster then normal weather conditions. Just for your safely! There also tricks on YouTube how keep your battery's in good condition.
2016-2-20
DaveB68
Thanks guys, will charge again before each flight.
Much appreciated.
Dave
2016-2-20
QuadBart
Flight distance : 256506 ft
Its good idea to start with a full battery.  But I'll admit I've taken mine out several times with 50% or even a little less charge.  I just make sure I don't go too far and keep an eye on the battery...  This is usually when I want to  check something out.  Like take it in front of my house and do a quick check-out/test of something...
2016-2-20
pi-inthesky
Flight distance : 13058 ft
DaveB68 Posted at 2016-2-20 12:54
Much appreciated.
Always start a new days flying with 100% battery charge BUT its okay as you described to take another flight on  that same  battery on the sameday.Never run the battery to its minimum check your battery manual for information.Get to know your batteries like a girlfriend they dont take prisoners when there ignored or misused.
2016-2-20
Kneepuck
Flight distance : 275105 ft
If you want scary reasons why to always fly with not just a full charge,   but a FRESH full charge,  simply browse this forum for posts about P3's falling out of the sky.
2016-2-20
