RONIN M for vertical shots ?
3021 1 2016-2-20
coolpix
Belgium
Hello,
I would like to use the ROnin M for vertical shots using either video or industrial high resolution medium format aerial cameras.
Can the RONIN M fully stabilize vertically (NADIR) ? without Gimbal lock ?
Is the system suited for using low shutter speed for photographic applications ?
Thanks for your reply
2016-2-20
DJI-Adela
The Ronin-M supports a wide variety of camera systems that weigh less than 3.6kg (8lbs). This includes the Sony A7S, Canon 5D, Nikon D800, Panasonic GH4, and more. The Ronin-M can be easily balanced and auto-tunes to support your preferred setup.
The Ronin-M was designed for handheld stabilization but features a quick-release mount that may be attached to compatible aircraft. Note that the Ronin-M does not have a dedicated aerial damping plate or rubber dampers and stabilization results when flying may vary. Any flying platform that the Ronin-M is attached to must meet the flight payload requirements for both the Ronin-M and your camera system.
2016-2-24
