Aeromirage
Flight distance : 1778045 ft
I have upgraded my Inspire 1 V2.0 to Pro by adding a Zenmuse X5 camera and a set of the Landing gear risers.
All working well with one exception. When I put the bird into Travel mode now it goes a little too far. So, instead of the arms being straight out (Horizontal) they are slightly up. This makes the bottom of the bird hit the foam liner of the case and keeps the arms slightly above the "stirrips' on the sides of the case.
What I have done as a temporary fix is I place a 5/8" thick item under the VPS eye while it lowers into travel mode which is working. (Makes sense since the risers added 5/8" to the height of the landing gear)
Has anyone else had this happen? Is there a way to adjust this?
