Battery Charging Hub
656 2 2016-2-21
fpbl
Hello,
Am I the only one having issues with the Battery Charging Hub.......this is got to be the biggest crap dji has done. It only charges one battery and they are constantly coming off the Hub.......Please, tell me that is not me I have done everything i can possibly do on my end.....Please HELP !!!
2016-2-21
dahazlehurst
Flight distance : 5128 ft
Hi.It only charges one battery at a time it starts with the most charged and then goes onto the second most charged then finishes with the leased charged.When i bought mine i did not read the specs properely i thought it charged all 4 at once but does not.Its needs to be put on a flat surfaced when you connect your battries to it.The battery is only a couple of mm from the base of the charger.Regards  Derek
2016-2-21
DJI-Amy
Hi, the charging hub will charge the battery one by one instead of charge them all at the same time. Have you tried to insert it into another pin?
2016-2-24
