Frustrating Phantom 3 "No Signal" problem
1467 6 2016-2-21
hessclark
I recently purchased a Phantom 3 Pro and after one of the iPad app updates I now have a "no signal" error when trying to show the live view from the DJI Go app on my iPad. The drone still flys fine and can take videos and photos but I can't view them until after they are taken and I go to the Home>Library section of the iPhone app.
Here are my current versions:
Phantom 3 Pro running firmware version 1.6.4.0
RC running firmware version 1.5.70
iPad app running version 2.6.0
Steps I have taken to resolve issue:
- Format memory card
- Update all firmware (batteries included)
- Tried it with an iPad and an iPhone
- Calibrated IMU
- Re-linked RC
- Remove and reinstall iPad app
- Restart iPad
Nothing has worked so far and I still have no image on the iPad app.... Please help get this resolved asap. Thanks!
2016-2-21
DJI-Tim
You seem to be done all the stuff  that could fix it.  I'm afraid you will have to contact your local DJI support center about the RMA
2016-2-21
titusllewelyn
I am now having the same problem with a Phantom 3 Advanced.  Right out of the box everything seemed Ok, until I attempted to fly and then it wanted a battery firmware upgrade.
After that, I had a couple of successful flights and this problem started.  Everything is the same except I am using the Android APP.
I have had a lot of model aircraft flight time and some droid time on another droid, so I find I can fly, but it obviously will not return to home.  If return to home is attempted it just wants to land wherever it is.
2016-2-28
DJI-Ken
Flight distance : 1515312 ft
titusllewelyn Posted at 2016-2-29 00:42
I am now having the same problem with a Phantom 3 Advanced.  Right out of the box everything seemed  ...
In the RTH settings, you can set it to RTH, hover, or land.
Also, if you are flying within 20m from where you took off (home point) then it will land.
In the academy section of the app is the full manual in PDF as well as a bunch of tutorial videos.
2016-2-28
DJI-Ken
Which iPad do you have, you need at least an iPad Air. If you have an original iPad or iPad 2 they will not work.
2016-2-28
Donnie
Flight distance : 3636782 ft
    Try another cable from the Transmitter to the I pad.
worth a shot- donnie
2016-2-29
Donnie
    Try a different cable from Transmitter to I pad
worth a shot - donnie
2016-2-29
