jimdaway
Hey Everyone;
I have a Phantom 2V+ Ver3 that I purchased in late December. I don't remember how it reacted when yawing when it was still "just out of the box" as I was learning, nervous, excited ... well, you get it.
Just after buying it, I did perform a firmware upgrade, poke at all the setting and perform an advanced IMU cali. The yaw-drift has been there ever since AND becuase I don't remember exactly how it acted out of the box, I can't confirm whether it was happening before the IMU calibration. My drift is to the rear, left) when yawing in position.
However, since finding this forum thread (after reading a LOT of other threads), I tried this over the weekend and it really helped. I think I need to fine tune it a little more but the wind was also a factor yesterday during my tests.
I want to send a HUGE thank you to Cory and Jamie for originally starting, investigating and apparently solving this issue! You guys really do deserve some serious good karma for your work!
With regards to the various methods mentioned here, I believe that there are only two methods that will work 100% and those are: 1) the trial-and-error method of shimming the struts OR 2) opening the top and placing a spirit level on the IMU.
It seems that the entire issue comes down the the "levelness" of the IMU when performing a calibration, isn't it?
If the IMU is mounted with 2-sided tape and it's level can vary from drone to drone, then there really is no correlation between the prop shafts and the level of the IMU, so leveling based on the prop shafts shouldn't do anything - right? Or, am I missing something here?
Anyway, I think that a spirit bubble level on the IMU would be the definitive way to take care of this but I really don't want to open the drone. I've got the yaw-drift to almost disappear with the trial-and-error method of shimming the struts and I'm so relieved. This IS my first rodeo with a higher-end drone.
Thanks again to everyone for sticking with this thread and working this through.
