Map don't load in the app
607 4 2016-2-23
joostpoeldijk
When i am connected to the wifi controller i cant load my google maps map in the app. My 3G wil not go on because i have wfi. Can someone help me with this. It works on IOS but i have an android Phone.
2016-2-23
DJI-Amy
What android phone do you use? You can try to enter the map and drag it to load, then the map should be saved.
2016-2-24
joostpoeldijk
DJI-Amy Posted at 2016-2-24 09:45
What android phone do you use? You can try to enter the map and drag it to load, then the map should ...
I have a Xperia Z, But i cant load the map because i am connected to the WiFi.
2016-2-24
DJI-Amy
joostpoeldijk Posted at 2016-2-24 16:47
Then you need to disconnect the WIFI controller first. You can enter the app only and load the map, then you can switch to the wifi of aircraft.
2016-2-24
joostpoeldijk
DJI-Amy Posted at 2016-2-24 09:50
Then you need to disconnect the WIFI controller first. You can enter the app only and load the map ...
Oke thanks, i will try it
2016-2-24
