Follow me - Google Nexus 7 problems
774 1 2016-2-24
nick4098
I use a Nexus 7 II tablet to fly my P3A with DJI Go app.  It all works fine, EXCEPT I can't get the 'follow me' mode to work.  POI works fine, though.
I'm pretty sure the Nexus has a GPS chip, and ought to work with follow me.
Does anyone have any experience of using this tablet with follow me, and if so did it work for you?  Are there any settings I have missed that I should change to get it working?
Thanks in advance.
Nick
2016-2-24
DJI-Amy
Are you sure that your tablet have a GPS module? Cause for most tablet, this part is not necessary unless it have the cellular function.  By the way, that does the app show when you tried to use the follow me function. In the map, you can check whether the circle is blue or not, cause only when the circle becomes  blue, can the follow me be activated. Red circle means the GPS signal is not strong enough.
2016-2-24
