johnsr
Flight distance : 1579022 ft
Good start & it look's like you have a really good place to work on technical aspects. As Amy points out, try to make your gimbal movements slower. Begin by taking a look at slowing the gimbal wheel speed slider (RC setting menu) and then reduce the expo of the gimbal pitch control (Gimbal - advanced settings menu). Keep in mind that viewers need a steady frame of reference (its OK to change it, if you do it smoothly). You can do this at home with the camera on (without props) to see what happens. This also means trying not to make abrupt flight direction changes. Also, you've discovered how difficult it is to fly a really straight line. Keep working, practice, practice, it will come!
Have fun & good flying! |
