Geebax
If you see the props at the top of your pictures there are a couple of solutions available to you. First, slow down your forward motion, they normally only appear when you are accelerating fast. Second, tilt the camer down slightly. If you are seeing the props, you are probably seeing too much sky as well.
Jello is caused by vibration of the camera, and the only practical solution is to remove the vibration. The first thing is to make sure you do not have all 4 gimbal retainer clips fitted, only two should be fitted.
Next, with the aircraft sitting on a bench, check to see if the camera is vibrating. If so, back off the control gains and see if that eliminates the problem.
The last check is to make sure your props are properly balanced, out of balance in the props will most certainly cause jello. |
