After firmware update onRonin M i have a problem.
953 5 2016-2-27
jason
After updating my ronin m, when i use the thumb control or Rc Control it turns a few degrees and stops even if i keep the Pan stick all the way to one side.Any ideas?
2016-2-27
DJI-Amy
Have you upgraded the remote controller? The RC also needs to be upgraded.
2016-2-28
jason
DJI-Amy Posted at 2016-2-28 22:27
I did that, thanks
2016-3-1
DJI-Adela
Hello!
Please refer to below information about Ronin-M:
WORKING PERFORMANCE
Load Weight (Reference Value)        3.6kg (8lb)
Angular Vibration Range        ± 0.02°
Maximum Controlled Rotation Speed        · Pan axis: 90°/s
        · Tilt axis: 100°/s
        · Roll axis: 30°/s
Mechanical Endpoint Range        · Pan axis: 360°
                                                        · Tilt axis: +105° /-190°
                                                        · Roll axis: ± 110°
Controlled Rotation Range   · Pan axis control: 360°
                                                  · Tilt axis control: +105° /-190°
                                                  · Roll axis control: ± 25°
2016-3-1
jason
That's it dji AMY, thanks.  Now can you help me  tune my ronin m for my multirotor? That would make you even more Amazing
2016-3-2
DJI-Amy
jason@jasonherr Posted at 2016-3-3 07:18
That's it dji AMY, thanks.  Now can you help me  tune my ronin m for my multirotor? That would mak ...
Since the Ronin-M is for handheld use, if you put it on the multirotor, you might have a stabilization problem.
2016-3-2
